[official]qBittorrent 3.3.16 installer - Built with MSVC 2017
Link to 3.3.16 post-> index.php/topic,3982.msg26056.html#msg26056
*****ORIGINAL POST BELOW****
Here is qBittorrent 3.3.0 built with MSVC 2013 express.
3.3.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.0.7 (final)
Qt: 5.5.1
Boost: 1.59.0
Small number of changes since RC. See here.
Last edited by sledgehammer_999 on Thu Sep 07, 2017 11:08 pm, edited 1 time in total.
Re: [official]qBittorrent 3.3.0 installer - Built with MSVC 2013
Thanks alot sledge and everyone at Github who put their time, effort and work into it making it possible for such a great release.
tekko
Post by tekko »
For the "missing file" thing, does it fix old affected resume files? or do I have to remove and re-add all torrents to create new ones?
If I understood the problem correctly... The completed torrents can actually be incomplete/corrupted if the bug has occured. It didn't matter if you manually rechecked or not, it will go to 100% anyway.
I have been quite updated with the 3.3.0 alpha/beta releases, so I want to know if my completed and removed torrents can actually be corrupted...
tekko
Post by tekko »
Re-added my whole list and rechecking them. A few torrents became 0% and "queued for checking" again right after the "checking" state. They are previewable, so they're not 0% for sure. I have a long list and still checking. I'm rushing to leave this comment because I think you might want to take it down as a stable release until further testings are done.
The issue about "missing files" that I fixed is something else. I don't know what you had. Your best option is to recheck the torrents and after that the status should be much more stable.
If you still have problems, describe it more and with screenshots.
fusk
Post by fusk »
Seems like the temp drive bug is still present.
Where using a temp drive makes qbit copy every download back onto the temp drive when windows starts.
So qbit first downloads to temp, then moves to destination. After computer restart it will copy from destination back to temp drive. Even tho save path is not the temp drive. It does not recheck the torrents, just moves them.
Maybe i should post this on github.
tekko
Post by tekko »
[quote="sledgehammer_999"]
The whole list finished checking anyway at the end. i.e. After the rest of the list is rechecked, it went back and checked the ones that were queued again.
I was asking about the "missing files" status because I saw this => https://github.com/qbittorrent/qBittorrent/issues/3602.
I did swap drives with 3.3.0 pre-stables, and I saw the "missing files" status; therefore, I was worried about the torrents I completed and removed were actually corrupted. Even though I "forced recheck" them at least once before removing, it seems that the completed payload still can be corrupted and show 100%?
I don't have connection problems like the others though.
You are confusing me. What are you seeing now? What is the problem now?(if you have any)
tekko
Post by tekko »
I don't quite understand about the "overwriting". If qbt is just redownloading the completed parts, then nothing should be corrupted right? i.e. only bandwidth was wasted?
[quote="tekko"]
I still don't understand if you have a problem and what problem that is. Assume that you are reporting this for the first time.
tekko
Post by tekko »
Nevermind. I was just trying to understand the bug that was reported and see if my downloads were corrupted in some way.
Sorry about the confusion.
Then I assume you don't have a problem now, correct?
The bug you linked wasn't followed up by the reporter. However, I found 2 cases where the .fastresume would be incorrectly overwritten when the files were actually missing. After a restart even if they appeared qbt had stored the new (and empty) status of the torrents and begun redownloading.
tekko
Post by tekko »
Yes, no problem. Thanks.
Very stable so far, im happy with its performance.
I've been using Dayman's builds with Qt5 before without any issues also.
zava
Post by zava »
Excellent work, perfect stability (Win 7 x64 machine).
