Now, after the upgrade, magically, no connections. No errors in logs, port forwarding is still listed correctly in the router settings.
Restarted machine, double checked all settings, and of course, nothing is changed on my system except going to 3.2 to 3.3.
OSX 10.11.1 and QBitorrent 3.3.0
11/29/15 8:26 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 53983
11/29/15 8:25 PM - qBittorrent is successfully listening on interface 127.0.0.1 port: UDP/53983
11/29/15 8:25 PM - qBittorrent is successfully listening on interface 127.0.0.1 port: TCP/53983
11/29/15 8:25 PM - qBittorrent is successfully listening on interface 127.0.0.1 port: TCP_SSL/4433
11/29/15 8:25 PM - qBittorrent is trying to listen on interface 127.0.0.1 port: 53983
11/29/15 8:25 PM - qBittorrent didn't find an IPv4 local address to listen on
11/29/15 8:25 PM - Network configuration of en1 has changed, refreshing session binding
11/29/15 8:25 PM - Options were saved successfully.
11/29/15 8:25 PM - GeoIP database loaded. Type: GeoLite2-Country. Build time: Tue Nov 3 18:05:56 2015.
11/29/15 8:25 PM - UPnP / NAT-PMP support [ON]
11/29/15 8:25 PM - Embedded Tracker [OFF]
11/29/15 8:25 PM - Encryption support [OFF]
11/29/15 8:25 PM - Local Peer Discovery support [ON]
11/29/15 8:25 PM - PeX support [ON]
11/29/15 8:25 PM - DHT support [ON]
11/29/15 8:25 PM - Anonymous mode [OFF]
11/29/15 8:25 PM - HTTP User-Agent is 'qBittorrent v3.3.0'
11/29/15 8:25 PM - Peer ID: -qB3300-
11/29/15 8:25 PM - qBittorrent v3.3.0 started
