Hi, have a look at this thread & the one i linked to in the second post those may contain a solution for you
index.php/topic,4211.msg21843.html#msg21843
the tl;dr is that the release build of qbt has a shit version of libtorrent in it that can lead to port binding issues.
Theres a compiled version here with a fix for it if trying the instructions in those threads doesnt resolve the issue for you (rebind port/adapter)
http://builds.shiki.hu/temp/qbittorrent ... ue_5109.7z
All torrents stuck in "Downloading"
Re: All torrents stuck in "Downloading"
[quote="KitKat"]
That version you linked only has an .exe and a .pdb file in it -- is there something I should be doing to get it to run on my Mac?
[quote="KitKat"]
Also, the "any interface" option is what fixed it -- even though previously support staff said I had to it set to my proper connection. Seems to work, for now.
