So as we all know the webinterface isn't quite up to date with the GUI. This is posing an issue for me on a headless install.
Can somebody tell me which line to add to my configuration file so that qbittorrent adds the label to the torrent path?
thanks!
Append label in qbittorrent-nox
Re: Append label in qbittorrent-nox
Nothing to add just edit the one that says what it does,
Downloads\AppendLabel=true|false
All the various setting in qBittorrent.conf are named for what they do.
Thanks, my config did not have that line so I was finally able to make it work like it's supposed to.
