qbittorrent php new magnet?
foncubierta
Post by foncubierta »
Hi, I 'm trying to add a magnet to qBittorrent from php, for now I have this:
//Upload a blank cookie.txt to the same directory as this file with a CHMOD/Permission to 777
function login($url,$data){
    $fp = fopen("cookie.txt", "w");
    fclose($fp);
    $login = curl_init();
    curl_setopt($login, CURLOPT_COOKIEJAR, "cookie.txt");
    curl_setopt($login, CURLOPT_COOKIEFILE, "cookie.txt");
    curl_setopt($login, CURLOPT_TIMEOUT, 40000);
    curl_setopt($login, CURLOPT_RETURNTRANSFER, TRUE);
    curl_setopt($login, CURLOPT_URL, $url);
    curl_setopt($login, CURLOPT_USERAGENT, $_SERVER['HTTP_USER_AGENT']);
    curl_setopt($login, CURLOPT_FOLLOWLOCATION, TRUE);
    curl_setopt($login, CURLOPT_POST, TRUE);
    curl_setopt($login, CURLOPT_POSTFIELDS, $data);
    ob_start();
    return curl_exec ($login);
    ob_end_clean();
    curl_close ($login);
    unset($login);
function grab_page($site){
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
    curl_setopt($ch, CURLOPT_USERAGENT, $_SERVER['HTTP_USER_AGENT']);
    curl_setopt($ch, CURLOPT_TIMEOUT, 40);
    curl_setopt($ch, CURLOPT_COOKIEFILE, "cookie.txt");
    curl_setopt($ch, CURLOPT_URL, $site);
    ob_start();
    return curl_exec ($ch);
    ob_end_clean();
    curl_close ($ch);
function post_data($site,$data){
    $datapost = curl_init();
    $headers = array("Expect:");
    curl_setopt($datapost, CURLOPT_URL, $site);
        curl_setopt($datapost, CURLOPT_TIMEOUT, 40000);
    curl_setopt($datapost, CURLOPT_HEADER, TRUE);
        curl_setopt($datapost, CURLOPT_HTTPHEADER, $headers);
    curl_setopt($datapost, CURLOPT_USERAGENT, $_SERVER['HTTP_USER_AGENT']);
    curl_setopt($datapost, CURLOPT_POST, TRUE);
    curl_setopt($datapost, CURLOPT_POSTFIELDS, $data);
        curl_setopt($datapost, CURLOPT_COOKIEFILE, "cookie.txt");
    ob_start();
    return curl_exec ($datapost);
    ob_end_clean();
    curl_close ($datapost);
    unset($datapost);
login("http://62.2XX.XXX.XX:8080/login","usern ... sword=pass");
//grab_page("http://62.2XX.XXX.XX:8080");
post_data("http://62.2XX.XXX.XX:8080/command/downl ... a/announce'");
the torrent is added but does not end down is as if he were the tracker. Thanks in advance.
ciaobaby
Re: qbittorrent php new magnet?
Post by ciaobaby »
Version?
Operating series?
And
what does " but does not end down" mean?
