ORIGINAL POST BELOW
Here is a build of qBittorrent 3.4.0alpha sha1 b13c991f4b6 from git master with:
boost 1.60
libtorrent 1.0.8+git602dc02
qt: 5.6.0
Built using msvc2015
The master branch for now is basically what will become the next minor stable release aka v3.3.5.
You can see the changes from v3.3.4 below, but there is one change that needs attention. It is about the "Advanced Saving Management" or ASM. It is basically an overhaul of the old and simple labeling system.
Description can be found here and maybe here.
Please test ASM and report any issues on github, tagging glassez. You can do this by writing into the bug message:
@glassez
Link 1: http://www.fosshub.com/qBittorrent.html
