[official]qBittorrent 3.0.11 installer - Built with MSVC 2008 and uTP support
Re: qBittorrent 3.0.6+3.1.0alpha installers - Built with MSVC 2008 and uTP support
Suggestion: The version in the new alpha should be changed to distinguish between the different alphas. It will make bug reporting/handling less confusing.
i.e. 3.1.0alpha2 or 3.1.0alpha.date
No problem with 3.1.0alpha (26-12-2012) so far. Thanks.
Yeah alphas should be tagged or referred to by date of release. He did post it as qbittorrent_3.1.0alpha_setup261212.exe
Still same problem with mine, is it x64 specific? Anybody else using the latest alpha on x64? Or, perhaps we do need a specific 64-bit build?
[quote="loki"]
Doesn't work, some sort of BEX error/appcrash as soon as opened.
[quote="loki"]
If you mean this one, it has been reported with no resolution atm: https://github.com/qbittorrent/qBittorrent/issues/290
I really don't know what can be wrong here, maybe building process has changed somehow :-/
[quote="loki"]
[quote="loki"]
I meant within the program itself.
1. I have not changed the building process
2. Loki, I will try to provide you a build with 0.16.5libtorrent. Let's hope that this is a libtorrent bug
3. To change it within the program it would be technically a source change I should have the changes distributed also.
4. The sad part is that I have limited time now, so I will not be able to troubleshoot this or any other "serious" bug. I am not good with debugging from error reports/stacktraces/backtraces etc. I only do simple bugs.
5. ????
6. profit (lol)
5. ????
6. profit (lol)
Thanks for your effort sledge . By the way after installing this new alpha disk cache is at 128mb as default setting, or atleast with me. So if you're having high ram usage change it back to 16/32mb, by 16mb as default like previous builds.
Dayman: I don't think this is the issue either, https://github.com/qbittorrent/qBittorrent/issues/290
It crashes instantly upon open, when completed torrents already exist, or when adding a torrent to seed on clean install.
I tried disabling antivirus, no difference.
No problems with 3.0.5 I would hopefully point to libtorrent too since no build process changes...
Here is a build of qBittorrent 3.1.0alpha from git master (01-01-2013) with boost 1.52 and libtorrent 0.16.6
Link-> http://depositfiles.com/files/2sn3y582q
Have been using this release and I have been quite pleased.
That was until yesterday!
Yesterday I switch on DTH support, but no luck. At the same time utp connections were impossible.
I tried disabling/enabling Windows firewall = no luck.
I tried reverting to version 3.0.6 = no luck
So now I am (reluctantly) using µTorrent and DHT and udp functionality is back.
Does anybody have a clue to what has happened?
Unknown, I haven't had luck using his builds but speaking for the 64-bit builds latest 3.1, DHT works fine. Do you have it set to use different port for DHT? Mine uses same (disabled the option to use different port).
sledgehammer, if you have time...
libtorrent-rasterbar-0.16.7 and qBittorrent v3.0.7 are out.
Thanks.
0.16.7 release:
* fix string encoding in error messages
* handle error in read_piece and set_piece_deadline when torrent is removed
* DHT performance improvement
* attempt to handle ERROR_CANT_WAIT disk error on windows
* improve peers exchanged over PEX
* fixed rare crash in ut_metadata extension
* fixed files checking issue
* added missing pop_alerts() to python bindings
* fixed typos in configure script, inversing some feature-enable/disable flags
* added missing flag_update_subscribe to python bindings
* active_dht_limit, active_tracker_limit and active_lsd_limit now interpret -1 as infinite
Thanks.
0.16.7 release:
Yeah, I will do a new build. Probably today.
But out of curiosity, how the fuck do you guys do you keep track of new releases and are able to post so soon?
Here is qBittorrent 3.0.7 built with MSVC 2008 express.
3.0.7 link-> http://sourceforge.net/projects/qbittor ... e/download
Libraries's version used:
Libtorrent: 0.16.7
Qt: 4.8.4
Boost: 1.52.0
Openssl: 1.0.1c
Libtorrent: 0.16.7
Qt: 4.8.4
Boost: 1.52.0
Openssl: 1.0.1c
