Hello and THANK YOU FOR YOUR EFFORTS AND A GREAT PROGRAM!
Relative Noob here with qbittorrent. I probably just need to adjust a setting or two, maybe a firewall setting? Here is the situation.
Not using SOCKS or any proxy, not using a VPN (I know, need to get one soon)
Macbook pro late 2011, firewall enabled
OSX 10.11.5
qBittorrent Ver. 3.2.0
ISP TW Cable, ARRIS cable modem, firewall enabled
Here is the log, (it runs from bottom to top for some strange reason so read from early to latest time stamp)
(comment: below error message repeated many times)
7/19/16 11:13 PM - Reason: Psy Trance 3 (2013) file (/Volumes/Seagate Backup Plus Drive II 2TB/Tor Downloads/temp/Psy Trance 3 (2013)/19. Animalis - Sweet Lead.mp3.!qB) error: Operation not supported
7/19/16 11:13 PM - An I/O error occurred, 'Psy Trance 3 (2013)' paused.
7/19/16 11:13 PM - Couldn't download favico for url `http://rarbg.com/favicon.ico`. Reason: `The remote server refused the connection`
7/19/16 11:13 PM - 'magnet:?xt=urn:btih:91C432C0B8091FEC1BCA7CFDEC1829512F8C68ED&dn=va+psytrance+vol+3+finest+psytrance+goa+trance+music+2013+driftstar&tr=udp%3A%2F%2F9.rarbg.com%3A2710%2Fannounce&tr=udp%3A%2F%2Fglotorrents.pw%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80%2Fannounce&tr=udp%3A%2F%2Ftracker.opentrackr.org%3A1337%2Fannounce' added to download list.
(comment, the below error message is repeated many times, truncated, an additional stuck torrent from a magnet link appears above)
7/19/16 11:11 PM - Reason: WiiJManager.zip file (/Volumes/Seagate Backup Plus Drive II 2TB/Tor Downloads/temp/WiiJManager.zip) error: Operation not supported
7/19/16 11:11 PM - An I/O error occurred, 'WiiJManager.zip' paused.
7/19/16 11:10 PM - Embedded Tracker [OFF]
7/19/16 11:10 PM - Encryption support [ON]
7/19/16 11:10 PM - Local Peer Discovery support [ON]
7/19/16 11:10 PM - PeX support [ON]
7/19/16 11:10 PM - Anonymous mode [ON]
7/19/16 11:10 PM - HTTP user agent is qBittorrent v3.2.0
7/19/16 11:10 PM - UPnP / NAT-PMP support [ON]
When I add a torrent, the program quickly does it's thing, and then pauses the torrent. Often it restarts and begins the download. However on some torrents, most actually, it pauses frequently and never restarts. I can restart or force restart repeatedly but it almost always pauses and throws and error in the log:
Sometimes after pausing, it near panics, running at about 70% of allocated resources, then either calms down after a minute or very rarely crashes. Torrents take 20+ restarts to completely download. Bummer.
One of the logs recorded earlier said Error 04 - Operation not Supported. That number doesn't appear in the logs I included, I don't know if that helps.
Thanks in advance!
[Solved] Very frequent stall or pause, not too helpful error log
Re: Very frequent stall or pause, not too helpful error log
Setting Anon mode OFF , changed nothing, still lots of pausing, stalling and occasionally uses high CPU cycles. I changed file names, IPs and such to keep data private.
Message is as follows: "An I/O error occurred, 01-File [Name, Path] error: Operation not supported"
Here is the initial boot messages again:
7/20/16 5:28 PM - qBittorrent v3.2.0 started
7/20/16 5:29 PM - Reason: 01-Filname file (/Volumes/Seagate Backup Plus Drive II 2TB/Tor Downloads/temp/01- Filname.mp4.!qB) error: Operation not supported
7/20/16 5:29 PM - An I/O error occurred, '01- Filename' paused.
7/20/16 5:29 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 25402
7/20/16 5:29 PM - Embedded Tracker [OFF]
7/20/16 5:29 PM - Encryption support [ON]
7/20/16 5:29 PM - Local Peer Discovery support [ON]
7/20/16 5:29 PM - PeX support [ON]
7/20/16 5:29 PM - Anonymous mode [OFF]
7/20/16 5:29 PM - HTTP user agent is qBittorrent v3.2.0
7/20/16 5:29 PM - UPnP / NAT-PMP support [ON]
7/20/16 5:28 PM - Couldn't download favico for url `http://rarbg.me/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://rarbg.to/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://leechers-paradise.org/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://eddie4.nl/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://coppersurfer.tk/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://trackerfix.com/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://arenabg.com/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://glotorrents.pw/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://openbittorrent.com/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - Couldn't download favico for url `http://opentrackr.org/favicon.ico`. Reason: `The remote server refused the connection`
7/20/16 5:28 PM - External IP: 76.XX.XXX.22
7/20/16 5:28 PM - Reason: Wheeler.Dealers.S12E04.BMW.2002TII.1080P.HDTV.x264-skorpion.mp4 fast resume rejected: mismatching file timestamp
7/20/16 5:28 PM - Fast resume data was rejected for torrent Wheeler.Dealers.S12E04.BMW.2002TII.1080P.HDTV.x264-skorpion.mp4, checking again...
7/20/16 5:28 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: UDP/25402
7/20/16 5:28 PM - qBittorrent is successfully listening on interface :: port: TCP/25402
7/20/16 5:28 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/25402
7/20/16 5:28 PM - Options were saved successfully.
7/20/16 5:28 PM - '/Users/workaccount/Library/Application Support/qBittorrent/BT_backup/20679ecfd1ad7cdd3e16b414e0c4d.torrent' resumed. (fast resume)
7/20/16 5:28 PM - '/Users/workaccount/Library/Application Support/qBittorrent/BT_backup/b8dc77de861e6f72febafe2944bf7490.torrent' resumed. (fast resume)
7/20/16 5:28 PM - '/Users/workaccount/Library/Application Support/qBittorrent/BT_backup/6cdbf4bb79baf49fbbcf2a129214c93d9.torrent' resumed. (fast resume)
7/20/16 5:28 PM - Embedded Tracker [OFF]
7/20/16 5:28 PM - Encryption support [ON]
7/20/16 5:28 PM - Local Peer Discovery support [ON]
7/20/16 5:28 PM - PeX support [ON]
7/20/16 5:28 PM - DHT support [ON]
7/20/16 5:28 PM - Anonymous mode [OFF]
7/20/16 5:28 PM - HTTP user agent is qBittorrent v3.2.0
7/20/16 5:28 PM - UPnP / NAT-PMP support [ON]
7/20/16 5:28 PM - qBittorrent is trying to listen on any interface port: 25402
7/20/16 5:28 PM - Peer ID: -qB3200-
Thank you!!
Thank you!!
Maybe try 3.3.6 and see what happens?
or just wait for other mac users to reply. (I'm not using mac)
FIXED! Re: Very frequent stall or pause, not too helpful error log
Upgrading to the latest version fixed the problem. v3.3.6
Hopefully it lasts, seems I can't keep a torrent client stable for long for some reason.
I read somewhere that there are "peer" based slow down
methods being used against some clients, does it effect qBittorrent?
Thanks for reading.
Thanks for reading.
