Change seed ratio settings using webui/terminal qbittorrent-nox (raspberry pi3b)
harry-johnson
Post by harry-johnson »
Hi!
Is there anyway to change the seed ratio settings like when using the application (gui, which i have not installed) instead of the webui? I cant seem to find the setting using the webui.
I am running Raspbian Jessie on my Raspberry Pi 3B, with the latest qbittorrent-nox.
Can i edit a config file using the terminal or something like that?
Thanks a bunch!  ;D
(Let me know if this is posted in the wrong forum).
- Harry.
mhertz
Re: Change seed ratio settings using webui/terminal qbittorrent-nox (raspberry pi3b)
Post by mhertz »
Add/edit these two lines in '~/.config/qBittorrent/qBittorrent.conf':
Bittorrent\MaxRatio=1
Bittorrent\MaxRatioAction=1
This example will remove torrents reaching '1' as share-ratio.
