Ok, so i have been using qbittorrent with no problems for several months until today. What is my surprise that i open qbitorrent today and it cant connect with any torrent.
The yellow symbol appear in the bottom and it says no direct connections. I didnt touch anything at all. I lost all connections with all trackers for unknown reasons.
I have Upnp activated and i can see that some trackers are accesible but the majority isnt. Whats going on?? i never had this happen before.
Yellow status, no direct connections.
Re: Yellow status, no direct connections.
Ok, i solved it.
It looks that for any unknown reasons, qbittorrent changed my net interface for something i cant remember. Why? i dont have a clue.
Ah thanks, I get it:
Tools > Options > Advanced > QBittorrent section > Network Interface
Cheers!
Cheers!
