Hello, how often is there updates as my version is still 3.3.1 I'm on Ubuntu 16.04
Thank you ,
Jinx13
Updates to qBittorrent-nox
Re: Updates to qBittorrent-nox
I googled it for you.
sudo add-apt-repository ppa:qbittorrent-team/qbittorrent-stable
sudo apt-get update
Uptodate ppa from the qbt lead-dev/maintainer including -nox too.
sudo apt-get update
Thanks for the reply. I also googled it before returning here ??
There is no "schedule" for the PPA updates. It's usually fresh.
If you added up, did the commands (update & upgrade), you should be on 3.3.7.
[quote="Jinx13"]
I would be interested to know how upgrading to 3.3.7 goes for you.
I had a problem with peer and seed counts were way off (almost like they were swapped around) and connection behavior became strange, probably because the counts were not right.
Going back to the distro version went mostly ok for me, I lost all my labels but other wise it was ok.
Oh wait, your talking about the nox variant, sorry, still what I said might still apply ....
Ian
Ian
