Search results showing 0 out of 305
DandW
Post by DandW »
Hi
Just installed the new release 3.3.9. Was running 3.1.11 on ubuntu 14.04 and all was good until the search stopped working the other day. Installed the new release and the search kind of works now. No results from extratorrent which I can live with but, sometimes it says in the search results that it is showing 0 out of 305 or some other number and shows nothing on the screen. Have looked through and can't see anything that I might have missed. Thought maybe some new check box in the new version that might be checked and needs to be unchecked or something. Anyone else have this issue ?
Re: Search results showing 0 out of 305
Try re-enabling Search in View?
Try checking the execution log?
DandW
Post by DandW »
Thanks for the reply...I have looked at the logs and see nothing strange. I don't know how to re-enable Search in View..
I also have not been able to search extratorrent.cc for the last couple of weeks...strange.
evsh
Post by evsh »
"X out of Y" message means that there were Y results returned by search plugins, but only X passed filtering afterwards. Parameters of the filter are listed below the search field. Most likely the very first combo box is set to "name only" and this makes filter to reject results those names do not contain the search keywords. Switch it to "everywhere" to disable this kind of filtering.
