[SOLVED] Running External Program - BAT File - Copy Script
natelabo
Post by natelabo »
Can someone please tell me the syntax to run a BAT file?
I cannot get qBittorrent to execute it...
I have tried:
cmd.exe /C C:\Users\torrentuser\torrenthandler.bat "%D" "%N" "%L" "%C" "%F"
"C:\Users\torrentuser\torrenthandler.bat" "%D" "%N" "%L" "%C" "%F"
None of these have worked.
Recent convert from uTorrent. Love this program. Just can't get my script to run...
Setup:
Server 2012 R2
qBittorrent v3.3.10
**************** My last post includes the script and syntax to run *************
KitKat
Re: Running External Program - BAT File
Post by KitKat »
[quote="natelabo"]
This is the Correct Syntax Structure.
Quickly confirmed it wasn't an application fault with this test script.
echo Arg 1: %1 >> qbittorrentoutput.txt
echo Arg 2: %2 >> qbittorrentoutput.txt
echo Arg 3: %3 >> qbittorrentoutput.txt
echo Arg 4: %4 >> qbittorrentoutput.txt
echo Arg 5: %5 >> qbittorrentoutput.txt
And this launch parameter:
"C:\Folder1\Folder Space\torrenthandler.bat" "%D" "%N" "%L" "%C" "%F"
Please make sure your batch file actually works/the data you're passing to it with qbittorrent is what the script expects to see.
You can quickly check whether scripts execute properly by deleting a small file from a completed torrent and forcing a recheck.
The script i posted above will drop a .txt file into the same folder as the .bat file when executed that contains the values qbittorrent returns for those variables, it may be returning something unexpected!?
If your script moves files around or renames things you could have a permissions error, try running qbittorrent as administrator if you are not already?
natelabo
Post by natelabo »
KitKat Thanks for the reply.
I've tried running as administrator and a standard user.
I copied your test script...
It says that it runs in the logs... Yet nothing runs?
Anything else I could try?
KitKat
Post by KitKat »
Only thing i can think of (since everything you're doing is correct!) would be a group policy/standard preventing applications from directly calling cmd.exe
qbittorrent attempts to run "cmd.exe /c <your commandline here>"
eg "cmd.exe /c "C:\script.bat" "%F""
Try pressing the windows key + R to open the run menu then enter cmd.exe, if command prompt does not popup then it could be a Path variable issue.
Worstcase you can downgrade to version 3.3.3 and use the commandline: cmd.exe /c "<your commandline here>"
As the method + syntax for running external programs changed in version 3.3.4
Old syntax was: [quote="natelabo"]
If its not a permissions/policy/path error on your machine, i'd suggest opening an issue ticket on the tracker:
https://github.com/qbittorrent/qBittorrent/
And linking to this thread and summarising the problem.
natelabo
Post by natelabo »
KitKat thanks for your input...
Further testing looks like this syntax is working for me:
C:\Users\torrentuser\torrenthandler.bat "%N" "%L" "%F" "%C"
I had to modify my batch script...
If anyone is interested I am using it to copy data to a storage location. Code looks like this:
@echo off
echo ********************************************* >> C:\Users\torrentuser\Desktop\CopyProgress.txt
echo Run on %date% at %time% >> C:\Users\torrentuser\Desktop\CopyProgress.txt
set name=%1
set category=%2
set contentpath=%3
set filecount=%4
set savepartition=\\STORAGE\Media\New
rem If category is "Music"
if %category%=="Music" goto music
rem If category is "Shows"
if %category%=="Shows" goto shows
rem If category is "Movies"
if %category%=="Movies" goto movies
rem If category is "Books"
if %category%=="Books" goto books
rem If category is "Blank"
echo **Undefined >> C:\Users\torrentuser\Desktop\CopyProgress.txt
rem Double underscores so the folders are easier to spot (listed on top in explorer)
set todir=%savepartition%\__%name%
goto filecount
:music
echo **Music >> C:\Users\torrentuser\Desktop\CopyProgress.txt
set todir=%savepartition%\Music\%name%
goto filecount
:shows
echo **Shows >> C:\Users\torrentuser\Desktop\CopyProgress.txt
set todir=%savepartition%\Shows\%name%
goto filecount
:movies
echo **Movies >> C:\Users\torrentuser\Desktop\CopyProgress.txt
set todir=%savepartition%\Movies\%name%
goto filecount
:books
echo **Books >> C:\Users\torrentuser\Desktop\CopyProgress.txt
set todir=%savepartition%\Books\%name%
goto filecount
:filecount
echo todir = %todir >> C:\Users\torrentuser\Desktop\CopyProgress.txt
rem Determine Torrent filecount
if %filecount%=="1" goto copyfile
if not %filecount%=="1" goto copyall
:copyall
echo Copy all contents of %contentpath% to %todir% >> C:\Users\torrentuser\Desktop\CopyProgress.txt
xcopy %contentpath%\*.* %todir% /S /I /Y
goto write
:copyfile
rem Copies single file from fromdir to todir
echo Copy %contentpath% to %todir% >> C:\Users\torrentuser\Desktop\CopyProgress.txt
xcopy %contentpath% %todir%\ /Y
goto write
:write
if errorlevel 4 goto lowmemory
if errorlevel 0 goto noerrors
:lowmemory
echo %date% at %time%: Handled torrent %name% %category% - FAILED >> C:\Users\torrentuser\Desktop\HandledTorrents.txt
goto exit
:noerrors
echo %date% at %time%: Handled torrent %name% %category% >> C:\Users\torrentuser\Desktop\HandledTorrents.txt
goto exit
:exit
end
I am not the original creator of the script... But I'm not sure of where I got it from. Hope the original creator doesn't mind me posting it...
