Using a vpn
Eqyliq
Using a vpn
Post by Eqyliq »
I have recently started using QBittorent without a VPN, however browsing the forum i've read that i should not, so i downloaded OpenVPN and set up the free vpn service offered by VPNbook, is it good? If not, any good free vpn service that you would reccomend?
I noticed that when the vpn is connected torrents tend to stall, or to not start; is there a way to avoid this?
Is simply turning on the vpn enough to make yourself anonymous? Or is possible to have a link to a step-by-step guide?
Thanks!
Switeck
Re: Using a vpn
Post by Switeck »
Warning: If you're using a VPN or proxy:    index.php/topic,5085.0.html
willieaames
Re: Using a vpn
Post by willieaames »
[quote="Eqyliq"]
I have recently started using QBittorent without a VPN, however browsing the forum I've read that I should not, so I downloaded OpenVPN and set up the free VPN service offered by VPNbook, is it good? If not, any good free VPN service that you would recommend?
I noticed that when the VPN is connected torrents tend to stall, or to not start; is there a way to avoid this?
Is simply turning on the VPN enough to make yourself anonymous? Or is possible to have a link to a step-by-step guide?
Thanks!
Free VPN is not secure as I have personal experience, instead, you should buy any budget VPN for your secure browsing on the internet.
ulrichneilson
Re: Using a vpn
Post by ulrichneilson »
I recently started using QBittorent without a VPN, but while reading the forum, I shouldn't do it because I've downloaded OpenVPN and the free VPN service is provided by VPNbook. ito? If not, what good free VPN service do you recommend?
ulrichneilson
Re: Using a vpn
willieaames wrote: Thu Sep 19, 2019 12:08 pm
Eqyliq wrote: Hi,
Thanks!
Free VPN is not secure as I have personal experience, instead, you should buy any for your secure browsing on the internet.
I recently started using QBittorent without a blackfriday vpn , but while reading the forum, I shouldn't do it because I've downloaded OpenVPN and the free VPN service is provided by VPNbook. ito? If not, what good free VPN service do you recommend?
