[quote="Ryrynz"]
Cheers. I've been using that test build posted above, I've encountered times where the UI will not launch this happens every few days or so, while remote interacts with it fine and the taskbar icon shows transferring data. Only way I can fix it is by closing the app forcefully and restarting. Any ideas if this has been fixed?
Did you post it as an issue on github?
[official]qBittorrent 4.0.4 installer - Built with MSVC 2017
Re: [official]qBittorrent 4.0.4 installer - Built with MSVC 2017
Nah, I'll wait till the next release is cut before I do that.
- Member
I'm running 4.0.4 and having issues with 'run external program'. I've seen some github comments that using 4.0.3 is the workaround for right now.
- Veteran
[quote="chaoticbeliever"]
Updating to the most recent version (v4.1.3) might be a solution...
