Speed Issues
vinci
Speed Issues
Post by vinci »
Hey Fellas,
I'm her because I've troubles with qBittorrent. (obviously)
Even though i already limited my download-speed (global) to 1 MB/s (actually, I've 50 MB/s), and i usually use barely up to 3 connections at the same time is my Internet always shutting down after a few minutes.
For me, that's odd because I'm using LAN, with the ports all should be fine but well, I'm not very into it. Hence, I would be glad if you've any propositions to solve this problem.
Thanks,
Vincent
Switeck
Re: Speed Issues
Post by Switeck »
A software firewall may be mistaking BitTorrent traffic as 'hostile' and blocking the connection temporarily.
qBitTorrent probably has DHT or LPD enabled or high half open limit in advanced settings which is hard on weak networking equipment.
