So I stupidly unchecked all the headers on the Transfer list, ie, now I can't see anything being uploaded or downloaded...
Any idea how to turn the headers back on?
Headers gone how to reset?
Re: Headers gone how to reset?
Probably best to reset to default, delete the config file, it should recreate the default config.
Re: Transfer list headers question
Same for Windows, see other post... it may be a bit harder to find the config file since Windows normally hides it. It should be C:\{user name}\appdata\roaming\qbittorrent\qbittorrent.ini
No need two themes for the same thing so i merged them and moved it here.
I tried to delete the configs but didn't have permission, even though I'm the admin... I'm using Ubuntu natty btw
something like... sudo rm {filename}
Of course you have to know where the file is located first...
