[4.0.2] Torrent keeps rechecking after opening qBittorrent
ovingiv
Post by ovingiv »
I'm running the latest official update on Windows 10 Winter Update. I've had this issue before on update 4.0.0 but after updating to the latest one that issue had gone away. But until recently, that same issue came back with me adding a torrent to reseed and it is in a constant rechecking loop and I can't stop it. I've tried to restart qBit and have restarted my pc multiple times to no avail. Is anyone having this issue and or has found a fix for this?
bob1324
Re: [4.0.2] Torrent keeps rechecking after opening qBittorrent
Post by bob1324 »
In advanced: uncheck: recheck torrents on completion.
I put this in the buglist but it still isn't solved.
ovingiv
Post by ovingiv »
That did the trick. Thank you bob...
bob1324
Post by bob1324 »
Disappeared with 4.1.0.
Problem is backwith 4.1.1.  :'(
Windows 10 pro Dutch
