Hi everyone!
I would like to switch from ktorrent to qbittorrent but i have a problem. I have a lot of torrent seeding (more than 200) and of course i can't import them one by one. There is a script to do this work? Thanks
Migrate from ktorrent
Re: Migrate from ktorrent
File -> Add torrent file -> select all your torrents.
Set in qBittorrent the same location for the downloads as in ktorrent, so seeding to continue after checking.
Thanks for the answer but it's not really useful. I've a lot of torrents, all downloaded in different folders, sometimes the files are even renamed. I need something that reads the specific ktorrent meta data for every torrent i have and import it inside qbittorrent. Is that possible?
I don't think so, in fact there's probably no such feature from any client. You can do as the other poster said or... another option, just run both until your done seeding the old torrents with ktorrent and start new torrents in qB.
