I have 2 ISPs, main one is connected via ethernet, backup is using my wifi. I have to manually select wifi and close the client then relaunch if I want it to use wifi at all. Is there perhaps a way to use both at once without have to sandbox/vm multiple qbittorrents? The vm workaround is not even an option if only downloading 1 file.
Bonus suggestion: (button to restart client in 1 click)
Other thoughts: More hotkeys never hurt anybody. (unless you count a dev who doesn't have the time to add them!
) An example would be a hotkey for banning a peer or popping up the statistics window. There is a lot more space at the bottom of the gui for more status updates like # of connections, etc. which might eliminate the need for a statistics window also.
