Here's a strange situation:
I can add a new torrent and it starts downloading quite perfectly. Whilst I am downloading I get a fair share of uploading happening on the active download. Once the download has completed the status gets set to "paused" and uploading on that file ceases - a dreadful situation for somebody trying to maintain a good ratio!
Even if I manually set my "paused" torrent back to "seeding" in a few seconds it has changed back to "paused" again. I have tried everything I can to discover what is causing this problem but to no avail.
Any suggestion would be appreciated.
Also, and it is just an observation. One thing that qbittorrent seems to be sorely lacking is any form of Time/Age recording. There seems to be no way, for example, to determine which was the latest torrent completed or how long a torrent has been completed and has been seeding.
Can't seem to seed
Re: Can't seem to seed
Do you have (global) share ratio limit set?
Regarding your observation, if you look at the general tab it shows the information you seek.
I think loki is right. If your on a private tracker I wouldn't use the global share ratio option at all. Queue system can also interfere with uploading if not set right but would go back to queued not paused.
