[official]qBittorrent 4.1.7 installer - Built with MSVC 2017
Link to 4.1.7 post-> https://qbforums.shiki.hu/index.php/top ... l#msg31784
*****ORIGINAL POST BELOW****
Here is qBittorrent 4.1.0 built with MSVC 2017.
4.1.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.1.7+git8808eb7cdd
Qt: 5.6.3 (32-bit) / 5.10.1 (64-bit)
Boost: 1.67.0
Last edited by sledgehammer_999 on Tue Aug 06, 2019 6:13 pm, edited 1 time in total.
Re: [official]qBittorrent 4.1.0 installer - Built with MSVC 2017
Thanks sledge.
Very nice release, fixes every report I had on Github previously.
Ryrynz
Post by Ryrynz »
Hi Sledge, could you see if in the next release you can make qBittorrent more robust finding files when rechecking?
If I don't have the directory in my 'default save path' it just won't pick up the files, doing a recheck yields no results. The save path is corrent (folder containing sub folder of torrent name)
This is the issue I commented on in the previous beta thread and appears to be a rather long standing issue.
[quote="Ryrynz"]
Do you use the "keep incomplete torrents in" option?
Care to rewrite the steps to reproduce?
Madoka
Post by Madoka »
[quote="Ryrynz"]
I have the same issue. I do not have "Keep incomplete torrent" activated.
My default folder is called "Bittorrent". Brilliant, right? I download a six episode video series, and qB puts it in a subfolder in "Bittorrent": say the "TV Show" folder in "Bittorrent." This is from a public tracker.
I can also seed this on a private tracker, as the uploader posts on multiple trackers. I download the torrent from the private tracker. If I leave the "TV show" folder in my default folder "Bittorrent", it finds and rechecks it just fine and I'm off to seed.
However, I like to keep my seeds for private trackers in subfolders, so I move the TV show folder before downloading the torrent from the private tracker. Now it's in Bittorrent>Private seeds>TV Show. I download the torrent from the private tracker, pause it, and set the download folder to "Private seeds", and start the torrent. Now qB cannot find the video files. It says I'm at 0% and will try to redownload the video files.
But, if I leave the "TV Show" folder in "Bittorrent", qB finds the folder and videos just fine and rechecks them. I can then set the download directory in the contextual menu to "Private seeds". qB will move the video files into a new subfolder in "Private Seed", but will leave the original folder in "Bittorrent" but it's now empty. Both have the exact same name. So it's like qB wants to create the folder in the "Private Seed" folder itself, and does not recognize a pre-made folder already placed there as it left the pre-made folder empty.
Ryrynz
Post by Ryrynz »
Yeah that's exactly it. I just now had some semi torrent downloaded files in a folder, lets called it c:\1\1, now I had downloaded the entire content from elsewhere to c:\1\2, so of course I want to change the location and recheck to full. I renamed the torrent name from 1 to 2 within qBitorrent so it matched the folder name but of course that didn't update the directory link internally so I 'set location' to c:\1 and you would think that because the torrent name is 2 and the directory 2 is there under c:\1 it would pick it up, but it doesn't, it's still stuck linked to c:\1\1. So I deleted c:\1\1 and renamed c:\1\2 to c:\1\1 and of course it rechecked fine.
Alternatively like I said I probably could've moved c:\1\2 to my default download directory and it would have it picked it up there but that was 30GB so I took a shortcut.
[quote="Madoka"]
[quote="Ryrynz"]
[quote="Ryrynz"]
I've reproduced it locally, and now I reported the bug to libtorrent. Follow this bug report: https://github.com/arvidn/libtorrent/issues/3021
I hadn't noticed the bug because I never follow your workflow.
In the meantime I suggest the following workflow (where applicable):
If you already have data of a torrent, then, when you are adding the torrent, point it to the correct path and let it recheck after you add it. Don't point it to the default path and then change location to where the files actually are.
The "Add new torrent" dialog is there for a reason. Use it.
Madoka
Post by Madoka »
Thank you for looking into this and your advice.
When I download a torrent I have the option to "Open it in qB" which I do. But that brought up the Add torrent dialog box every time. Since for 99.9% of my torrents I just want it to start, when I first installed qB I turned off the "Display torrent options box" and forgot all about it.
Now I'll save the torrent in the monitored folder to avoid that dialog box, but have the dialog box activated when I Open a torrent with qB.
Ryrynz
Post by Ryrynz »
Nice. On another note, I got a few of these in my log. 11-May-18 1:55 AM - 54.193.141.44 was blocked due to IP filter.
I'm not using an IP filter though, is this some auto blocking feature? If so could it be clarified in the log?
[quote="Ryrynz"]
Tools->Options->Connection->IP Filtering->Manually banned IP addresses...
Is the list empty?
Also in the same section is the "Filter path (.dat, .p2p, .p2b)" checkbox unchecked?
Ryrynz
Post by Ryrynz »
Yeah empty and unchecked. Looked before posting, also I've never used them. Haven't seen any further log entries like this though.
On another note, could you copy the below layout for qbittorrent's mouse over the tray icon? I think ATM it's a bit spartan and can be improved by mirroring uTorrent's mouse over info. Cheers.
Here is qBittorrent 4.1.1 built with MSVC 2017.
4.1.1 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.1.7+git6ec6c1b340
Boost: 1.67.0
freesolo
Re: [official]qBittorrent 4.1.1 installer - Built with MSVC 2017
Post by freesolo »
Hi, would it be possible to have more details on the following feature for v4.1.1:
FEATURE: Relax behavior of "Download first and last piece first". It applies to all files and not only to the previewable. (Chocobo1)
I can't find what exactly has been modified. Thanks.
[quote="freesolo"]
Till now, qbt fetched the 1st and last piece only of previewable files (think media files, avi, mkv, mp4 etc). Now it does it for all kinds of file types.
PR: https://github.com/qbittorrent/qBittorrent/pull/8954
Ryrynz
Post by Ryrynz »
Where can I find the changes applicable to 4.1.1 The change log lists everything.
