Found a fix for 4.1.0 "stalled" issue
apoulos
Post by apoulos »
Hi there,
I made an account because I wanted to share the fix that I found with the "stalled' issue in 4.1.0 - some people have been reporting this issue.  I disabled "use my router UPNP/ NAT-PMP" as many ISPs have started to block Port Forwarding.  You can still use random ports though!
Hopefully this helps.
A
Switeck
Re: Found a fix for 4.1.0 "stalled" issue
Post by Switeck »
If you manually forwarded your router port to the computer running qBitTorrent, you probably shouldn't be using UPnP/NAT-PMP enabled in qBT anyway because they can conflict with the manual port forward.
ledzeppelin
Post by ledzeppelin »
Thanks for this fix apoulos
I see an improvement in the download speed. However I am still on 4.0.3.
4.1.0 gives me low download speeds
bcarney
Post by bcarney »
I had to roll back Window's April 2018 Update to get qbittorrent to work again.
rednoise
Post by rednoise »
[quote="apoulos"]
I wish it did help. Unfortunately for me, I still get the "stalled" condition whether I use UPnP or if I explicitly forward a port in my router. This is true of version every version since 4.03, including the new version 4.1.1.
This is only the case with dimeadozen.org. Other trackers I've tried it seem to with work OK.
user55
Post by user55 »
[quote="rednoise"]
You should probably try to tweak disk cache setting. I've set it to "-1 (auto)" and it solved my problem.
Adsixnine
Post by Adsixnine »
Thanks for this fix.  :)
mojo-chan
Post by mojo-chan »
None of these fixes worked for me.
As well as stalled torrents I get torrents that error or get stuck queued. Repeated forced resumes and re-checks eventually gets them to download but it's a manual process.
