Dark Theme
Ross
Dark Theme
Post by Ross »
Is there any further plan to develop a dark theme for the application?
I would really appreciate it!  ;D
AU4U
Re: Dark Theme
Post by AU4U »
Even the original Blue Skin Graph from early uTorrent would be great.
There is a drop in file to change the newer versions speed graph to blue.
Much easier on the eyes.
Can it be made to work here?
Blue Skin Graph.btskin file LINK: https://drive.google.com/open?id=12T7Os ... s7bYVCDdlC
RBert
Re: Dark Theme
Post by RBert »
Hello.
Yes please dark theme or more for the best torrent client.
If you need beta tester or help contact me.
Cordialy.
Adsixnine
Re: Dark Theme
Post by Adsixnine »
I love it  ;D
UtoQ
Re: Dark Theme
Post by UtoQ »
Hello
A dark theme is very important.
Please, can you do it.
And if you give the possibility to the community to do skins, it sould be wonderful.
Thanks.
kkwong7878
Re: Dark Theme
Post by kkwong7878 »
Extremely need a dark mode
Fuga
Re: Dark Theme
Post by Fuga »
Another request here for a dark mode!
JasonCarswell
Re: Dark Theme
Post by JasonCarswell »
I'd be willing to do a dark theme mockup if it was actually helpful.
Somehow I suspect something like a CSS is more in order, so that we can either load predefined colour schemes, other contributors schemes, or customize our own colours.
cantalupo
Re: Dark Theme
Post by cantalupo »
https://github.com/qbittorrent/qBittorrent/issues/6434
This request is very much wanted, I would very much appreciate receiving this update.  :D
geneziz
Re: Dark Theme
Post by geneziz »
i just made an account to say, i want a black theme aswell! its the only drawback to Qbittorrent!
Should have been such a easy fix for you guys to add in aswell, takes 20 min to add it, then push out an update!
dracho
Re: Dark Theme
Post by dracho »
Just use a custom visual style...
https://i.imgur.com/wfCD4Nq.png
I use Placebo Ashtray from SolMiler, found on deviantArt.
willco
Re: Dark Theme
Post by willco »
Any updates about Dark Theme?  looking forward to it
halobender
Re: Dark Theme
Post by halobender »
I was going to switch to qbit from ut, but I'm color blind and cannot see the text when the arrow is up. In ut the text is black and it's easy to determine status by the icons, why can't that be the case here? Or is there a way to do this already that I'm not seeing? Perhaps CSS? How do I change all the text to black?
Conscious_Fold
Re: Dark Theme
Post by Conscious_Fold »
Just set your kde system theme to something dark and qbittorrent will be dark (or light or whatever the theme looks like).
AbeSimpson
Re: Dark Theme
Post by AbeSimpson »
That's great, but not much use to Windows users
