The steps i have took to make it compile is long tedious ways, looks like on QT 5.11 the QRC compiler (qmlcache) has failed to convert the "mootools-1.2-core-yc.js" & "mootools-1.2-more.js" resources into manageable filename inside the qmlcache_loader.cpp.
So i need to rename the mootools-1.2-core-yc.js & mootools-1.2-more.js into mootools-core-yc.js & mootools-more.js, also replaced the filelist inside the webui.qrc .
Here is the qBittorrent compilation log
06:50:17: Running steps for project qbittorrent...
06:50:17: Starting: "C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmake.exe" C:\QBITTORRENT\qBittorrent\qbittorrent.pro -spec win32-msvc "CONFIG+=release" "CONFIG+=qtquickcompiler"
Info: creating stash file C:\QBITTORRENT\build-qbittorrent-Desktop-Release\.qmake.stash
Project MESSAGE: Building translations
Project MESSAGE: Processing lang/qbittorrent_ar
Project MESSAGE: Processing lang/qbittorrent_be
Project MESSAGE: Processing lang/qbittorrent_bg
Project MESSAGE: Processing lang/qbittorrent_ca
Project MESSAGE: Processing lang/qbittorrent_cs
Project MESSAGE: Processing lang/qbittorrent_da
Project MESSAGE: Processing lang/qbittorrent_de
Project MESSAGE: Processing lang/qbittorrent_el
Project MESSAGE: Processing lang/qbittorrent_en
Project MESSAGE: Processing lang/qbittorrent_en_AU
Project MESSAGE: Processing lang/qbittorrent_en_GB
Project MESSAGE: Processing lang/qbittorrent_eo
Project MESSAGE: Processing lang/qbittorrent_es
Project MESSAGE: Processing lang/qbittorrent_eu
Project MESSAGE: Processing lang/qbittorrent_fi
Project MESSAGE: Processing lang/qbittorrent_fr
Project MESSAGE: Processing lang/qbittorrent_gl
Project MESSAGE: Processing lang/qbittorrent_he
Project MESSAGE: Processing lang/qbittorrent_hi_IN
Project MESSAGE: Processing lang/qbittorrent_hr
Project MESSAGE: Processing lang/qbittorrent_hu
Project MESSAGE: Processing lang/qbittorrent_hy
Project MESSAGE: Processing lang/qbittorrent_id
Project MESSAGE: Processing lang/qbittorrent_is
Project MESSAGE: Processing lang/qbittorrent_it
Project MESSAGE: Processing lang/qbittorrent_ja
Project MESSAGE: Processing lang/qbittorrent_ka
Project MESSAGE: Processing lang/qbittorrent_ko
Project MESSAGE: Processing lang/qbittorrent_lt
Project MESSAGE: Processing lang/qbittorrent_lv_LV
Project MESSAGE: Processing lang/qbittorrent_ms_MY
Project MESSAGE: Processing lang/qbittorrent_nb
Project MESSAGE: Processing lang/qbittorrent_nl
Project MESSAGE: Processing lang/qbittorrent_oc
Project MESSAGE: Processing lang/qbittorrent_pl
Project MESSAGE: Processing lang/qbittorrent_pt_BR
Project MESSAGE: Processing lang/qbittorrent_pt_PT
Project MESSAGE: Processing lang/qbittorrent_ro
Project MESSAGE: Processing lang/qbittorrent_ru
Project MESSAGE: Processing lang/qbittorrent_sk
Project MESSAGE: Processing lang/qbittorrent_sl
Project MESSAGE: Processing lang/qbittorrent_sr
Project MESSAGE: Processing lang/qbittorrent_sv
Project MESSAGE: Processing lang/qbittorrent_tr
Project MESSAGE: Processing lang/qbittorrent_uk
Project MESSAGE: Processing lang/qbittorrent_uz@Latn
Project MESSAGE: Processing lang/qbittorrent_vi
Project MESSAGE: Processing lang/qbittorrent_zh
Project MESSAGE: Processing lang/qbittorrent_zh_HK
Project MESSAGE: Processing lang/qbittorrent_zh_TW
06:50:22: The process "C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmake.exe" exited normally.
06:50:22: Starting: "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" qmake_all
Microsoft (R) Program Maintenance Utility Version 14.14.26429.4
Copyright (C) Microsoft Corporation. All rights reserved.
cd src\ && C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmake.exe -o Makefile C:\QBITTORRENT\qBittorrent\src\src.pro -spec win32-msvc "CONFIG+=release" "CONFIG+=qtquickcompiler"
Project MESSAGE: Project is built in RELEASE mode.
Project MESSAGE: Disabling debug output.
Project MESSAGE: Project is built in DEBUG mode.
cd src\ && "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" -f Makefile qmake_all
06:50:30: The process "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" exited normally.
06:50:30: Starting: "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe"
cd src\ && ( if not exist Makefile C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmake.exe -o Makefile C:\QBITTORRENT\qBittorrent\src\src.pro -spec win32-msvc "CONFIG+=release" "CONFIG+=qtquickcompiler" ) && "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" -f Makefile
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" -f Makefile.Release
uic ..\..\qBittorrent\src\app\stacktrace_win_dlg.ui
uic ..\..\qBittorrent\src\gui\properties\peersadditiondlg.ui
uic ..\..\qBittorrent\src\gui\properties\propertieswidget.ui
uic ..\..\qBittorrent\src\gui\properties\trackersadditiondlg.ui
uic ..\..\qBittorrent\src\gui\about.ui
uic ..\..\qBittorrent\src\gui\addnewtorrentdialog.ui
uic ..\..\qBittorrent\src\gui\autoexpandabledialog.ui
uic ..\..\qBittorrent\src\gui\bandwidth_limit.ui
uic ..\..\qBittorrent\src\gui\banlistoptions.ui
uic ..\..\qBittorrent\src\gui\confirmdeletiondlg.ui
uic ..\..\qBittorrent\src\gui\cookiesdialog.ui
uic ..\..\qBittorrent\src\gui\downloadfromurldialog.ui
uic ..\..\qBittorrent\src\gui\executionlog.ui
uic ..\..\qBittorrent\src\gui\ipsubnetwhitelistoptionsdialog.ui
uic ..\..\qBittorrent\src\gui\login.ui
uic ..\..\qBittorrent\src\gui\mainwindow.ui
uic ..\..\qBittorrent\src\gui\optionsdlg.ui
uic ..\..\qBittorrent\src\gui\previewselectdialog.ui
uic ..\..\qBittorrent\src\gui\rss\automatedrssdownloader.ui
uic ..\..\qBittorrent\src\gui\rss\rsswidget.ui
uic ..\..\qBittorrent\src\gui\search\pluginselectdlg.ui
uic ..\..\qBittorrent\src\gui\search\pluginsourcedlg.ui
uic ..\..\qBittorrent\src\gui\search\searchtab.ui
uic ..\..\qBittorrent\src\gui\search\searchwidget.ui
uic ..\..\qBittorrent\src\gui\shutdownconfirmdlg.ui
uic ..\..\qBittorrent\src\gui\statsdialog.ui
uic ..\..\qBittorrent\src\gui\torrentcategorydialog.ui
uic ..\..\qBittorrent\src\gui\torrentcreatordlg.ui
uic ..\..\qBittorrent\src\gui\updownratiodlg.ui
rcc ..\..\qBittorrent\src\gui\about.qrc
rcc webui_webui_qmlcache.qrc
rcc ..\..\qBittorrent\src\icons.qrc
rcc ..\..\qBittorrent\src\lang.qrc
rcc ..\..\qBittorrent\src\searchengine.qrc
generating release/moc_predefs.h
moc ..\..\qBittorrent\src\app\qtsingleapplication\qtsingleapplication.h
moc ..\..\qBittorrent\src\app\qtsingleapplication\qtlocalpeer.h
moc ..\..\qBittorrent\src\app\application.h
moc ..\..\qBittorrent\src\app\filelogger.h
moc ..\..\qBittorrent\src\app\stacktrace_win_dlg.h
moc ..\..\qBittorrent\src\base\asyncfilestorage.h
moc ..\..\qBittorrent\src\base\bittorrent\private\bandwidthscheduler.h
moc ..\..\qBittorrent\src\base\bittorrent\private\filterparserthread.h
moc ..\..\qBittorrent\src\base\bittorrent\private\resumedatasavingmanager.h
moc ..\..\qBittorrent\src\base\bittorrent\private\statistics.h
moc ..\..\qBittorrent\src\base\bittorrent\session.h
moc ..\..\qBittorrent\src\base\bittorrent\torrentcreatorthread.h
moc ..\..\qBittorrent\src\base\bittorrent\tracker.h
moc ..\..\qBittorrent\src\base\filesystemwatcher.h
moc ..\..\qBittorrent\src\base\http\connection.h
moc ..\..\qBittorrent\src\base\http\server.h
moc ..\..\qBittorrent\src\base\logger.h
moc ..\..\qBittorrent\src\base\net\dnsupdater.h
moc ..\..\qBittorrent\src\base\net\downloadhandler.h
moc ..\..\qBittorrent\src\base\net\downloadmanager.h
moc ..\..\qBittorrent\src\base\net\geoipmanager.h
moc ..\..\qBittorrent\src\base\net\portforwarder.h
moc ..\..\qBittorrent\src\base\net\proxyconfigurationmanager.h
moc ..\..\qBittorrent\src\base\net\reverseresolution.h
moc ..\..\qBittorrent\src\base\net\smtp.h
moc ..\..\qBittorrent\src\base\preferences.h
moc ..\..\qBittorrent\src\base\rss\private\rss_parser.h
moc ..\..\qBittorrent\src\base\rss\rss_article.h
moc ..\..\qBittorrent\src\base\rss\rss_autodownloader.h
moc ..\..\qBittorrent\src\base\rss\rss_feed.h
moc ..\..\qBittorrent\src\base\rss\rss_folder.h
moc ..\..\qBittorrent\src\base\rss\rss_item.h
moc ..\..\qBittorrent\src\base\rss\rss_session.h
moc ..\..\qBittorrent\src\base\scanfoldersmodel.h
moc ..\..\qBittorrent\src\base\search\searchhandler.h
moc ..\..\qBittorrent\src\base\search\searchdownloadhandler.h
moc ..\..\qBittorrent\src\base\search\searchpluginmanager.h
moc ..\..\qBittorrent\src\base\settingsstorage.h
moc ..\..\qBittorrent\src\base\torrentfileguard.h
moc ..\..\qBittorrent\src\gui\lineedit\src\lineedit.h
moc ..\..\qBittorrent\src\gui\powermanagement\powermanagement.h
moc ..\..\qBittorrent\src\gui\properties\downloadedpiecesbar.h
moc ..\..\qBittorrent\src\gui\properties\peerlistdelegate.h
moc ..\..\qBittorrent\src\gui\properties\peerlistsortmodel.h
moc ..\..\qBittorrent\src\gui\properties\peerlistwidget.h
moc ..\..\qBittorrent\src\gui\properties\peersadditiondlg.h
moc ..\..\qBittorrent\src\gui\properties\pieceavailabilitybar.h
moc ..\..\qBittorrent\src\gui\properties\piecesbar.h
moc ..\..\qBittorrent\src\gui\properties\propertieswidget.h
moc ..\..\qBittorrent\src\gui\properties\proplistdelegate.h
moc ..\..\qBittorrent\src\gui\properties\proptabbar.h
moc ..\..\qBittorrent\src\gui\properties\speedplotview.h
moc ..\..\qBittorrent\src\gui\properties\speedwidget.h
moc ..\..\qBittorrent\src\gui\properties\trackerlist.h
moc ..\..\qBittorrent\src\gui\properties\trackersadditiondlg.h
moc ..\..\qBittorrent\src\gui\about_imp.h
moc ..\..\qBittorrent\src\gui\addnewtorrentdialog.h
moc ..\..\qBittorrent\src\gui\advancedsettings.h
moc ..\..\qBittorrent\src\gui\autoexpandabledialog.h
moc ..\..\qBittorrent\src\gui\banlistoptions.h
moc ..\..\qBittorrent\src\gui\categoryfiltermodel.h
moc ..\..\qBittorrent\src\gui\categoryfilterwidget.h
moc ..\..\qBittorrent\src\gui\cookiesdialog.h
moc ..\..\qBittorrent\src\gui\cookiesmodel.h
moc ..\..\qBittorrent\src\gui\deletionconfirmationdlg.h
moc ..\..\qBittorrent\src\gui\downloadfromurldialog.h
moc ..\..\qBittorrent\src\gui\executionlog.h
moc ..\..\qBittorrent\src\gui\fspathedit.h
moc ..\..\qBittorrent\src\gui\fspathedit_p.h
moc ..\..\qBittorrent\src\gui\guiiconprovider.h
moc ..\..\qBittorrent\src\gui\ipsubnetwhitelistoptionsdialog.h
moc ..\..\qBittorrent\src\gui\loglistwidget.h
moc ..\..\qBittorrent\src\gui\mainwindow.h
moc ..\..\qBittorrent\src\gui\messageboxraised.h
moc ..\..\qBittorrent\src\gui\optionsdlg.h
moc ..\..\qBittorrent\src\gui\previewlistdelegate.h
moc ..\..\qBittorrent\src\gui\previewselectdialog.h
moc ..\..\qBittorrent\src\gui\rss\articlelistwidget.h
moc ..\..\qBittorrent\src\gui\rss\automatedrssdownloader.h
moc ..\..\qBittorrent\src\gui\rss\feedlistwidget.h
moc ..\..\qBittorrent\src\gui\rss\htmlbrowser.h
moc ..\..\qBittorrent\src\gui\rss\rsswidget.h
moc ..\..\qBittorrent\src\gui\scanfoldersdelegate.h
moc ..\..\qBittorrent\src\gui\search\pluginselectdlg.h
moc ..\..\qBittorrent\src\gui\search\pluginsourcedlg.h
moc ..\..\qBittorrent\src\gui\search\searchtab.h
moc ..\..\qBittorrent\src\gui\search\searchwidget.h
moc ..\..\qBittorrent\src\gui\shutdownconfirmdlg.h
moc ..\..\qBittorrent\src\gui\speedlimitdlg.h
moc ..\..\qBittorrent\src\gui\statsdialog.h
moc ..\..\qBittorrent\src\gui\statusbar.h
moc ..\..\qBittorrent\src\gui\tagfiltermodel.h
moc ..\..\qBittorrent\src\gui\tagfilterwidget.h
moc ..\..\qBittorrent\src\gui\torrentcategorydialog.h
moc ..\..\qBittorrent\src\gui\torrentcontentfiltermodel.h
moc ..\..\qBittorrent\src\gui\torrentcontentmodel.h
moc ..\..\qBittorrent\src\gui\torrentcontenttreeview.h
moc ..\..\qBittorrent\src\gui\torrentcreatordlg.h
moc ..\..\qBittorrent\src\gui\torrentmodel.h
moc ..\..\qBittorrent\src\gui\trackerlogin.h
moc ..\..\qBittorrent\src\gui\transferlistdelegate.h
moc ..\..\qBittorrent\src\gui\transferlistfilterswidget.h
moc ..\..\qBittorrent\src\gui\transferlistsortmodel.h
moc ..\..\qBittorrent\src\gui\transferlistwidget.h
moc ..\..\qBittorrent\src\gui\updownratiodlg.h
moc ..\..\qBittorrent\src\gui\programupdater.h
moc ..\..\qBittorrent\src\webui\api\apicontroller.h
moc ..\..\qBittorrent\src\webui\api\appcontroller.h
moc ..\..\qBittorrent\src\webui\api\authcontroller.h
moc ..\..\qBittorrent\src\webui\api\logcontroller.h
moc ..\..\qBittorrent\src\webui\api\rsscontroller.h
moc ..\..\qBittorrent\src\webui\api\synccontroller.h
moc ..\..\qBittorrent\src\webui\api\torrentscontroller.h
moc ..\..\qBittorrent\src\webui\api\transfercontroller.h
moc ..\..\qBittorrent\src\webui\webapplication.h
moc ..\..\qBittorrent\src\webui\webui.h
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource-file-mapping="C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc=C:/QBITTORRENT/build-qbittorrent-Desktop-Release/src/webui_webui_qmlcache.qrc" -o release\qmlcache_loader.cpp ..\..\qBittorrent\src\webui\webui.qrc
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_misc_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\misc.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_client_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\client.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_mocha-init_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\mocha-init.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_progressbar_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\progressbar.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_prop-general_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\prop-general.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_prop-webseeds_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\prop-webseeds.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_prop-trackers_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\prop-trackers.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_dynamicTable_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\dynamicTable.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_contextmenu_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\contextmenu.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_download_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\download.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_prop-files_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\prop-files.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_clipboard.min_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\clipboard.min.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_mootools-core-yc_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\mootools-core-yc.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_fixpng_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\fixpng.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_excanvas-compressed_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\excanvas-compressed.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_mocha-yc_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\mocha-yc.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_mootools-more_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\mootools-more.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_private_scripts_lib_parametrics_js.cpp ..\..\qBittorrent\src\webui\www\private\scripts\lib\parametrics.js
C:\Dev\QT\Qt5.11\msvc2017_64\bin\qmlcachegen.exe --resource=C:/QBITTORRENT/qBittorrent/src/webui/webui.qrc -o release\webui_www_public_scripts_lib_mootools-core-yc_js.cpp ..\..\qBittorrent\src\webui\www\public\scripts\lib\mootools-core-yc.js
rc /NOLOGO -DUNICODE -D_UNICODE -DWIN32 -DWIN64 -DBOOST_NO_CXX11_RVALUE_REFERENCES -DBOOST_ASIO_HASH_MAP_BUCKETS=1021 -DBOOST_ASIO_DISABLE_CONNECTEX -DBOOST_EXCEPTION_DISABLE -DTORRENT_USE_OPENSSL -DUNICODE -D_UNICODE -DWIN32 -D_WIN32 -DWIN32_LEAN_AND_MEAN -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D__USE_W32_SOCKETS -D_FILE_OFFSET_BITS=64 -DNOMINMAX -DNDEBUG -DNTDDI_VERSION=0x05010000 -D_WIN32_WINNT=0x0501 -D_WIN32_IE=0x0501 -DBOOST_ALL_NO_LIB -DBOOST_SYSTEM_DYN_LINK -DBOOST_USE_WINAPI_VERSION=0x0501 -DTORRENT_LINKING_SHARED -DSTACKTRACE -DSTACKTRACE_WIN_PROJECT_PATH=C:/QBITTORRENT/qBittorrent/src -DSTACKTRACE_WIN_MAKEFILE_PATH=C:/QBITTORRENT/build-qbittorrent-Desktop-Release/src -DQT_NO_DEBUG_OUTPUT -DQBT_VERSION_MAJOR=4 -DQBT_VERSION_MINOR=2 -DQBT_VERSION_BUGFIX=0 -DQBT_VERSION_BUILD=0 -DQBT_VERSION=\"v4.2.0alpha\" -DQBT_VERSION_2=\"4.2.0alpha\" -DQT_NO_CAST_TO_ASCII -DQT_USE_QSTRINGBUILDER -DQT_STRICT_ITERATORS -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_QUICK_LIB -DQT_WINEXTRAS_LIB -DQT_GUI_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_CORE_LIB -fo release\qbittorrent.res ..\..\qBittorrent\src\qbittorrent.rc
qtsingleapplication.cpp
qtlocalpeer.cpp
Generating Code...
application.cpp
cmdoptions.cpp
filelogger.cpp
main.cpp
Generating Code...
asyncfilestorage.cpp
exceptions.cpp
filesystemwatcher.cpp
iconprovider.cpp
logger.cpp
preferences.cpp
profile.cpp
scanfoldersmodel.cpp
settingsstorage.cpp
torrentfileguard.cpp
torrentfilter.cpp
tristatebool.cpp
Generating Code...
infohash.cpp
magneturi.cpp
peerinfo.cpp
session.cpp
torrentcreatorthread.cpp
torrenthandle.cpp
torrentinfo.cpp
C:\QBittorrent\install_msvc64\base\include\libtorrent/error_code.hpp(504): warning C4275: non dll-interface class 'std::exception' used as base for dll-interface struct 'libtorrent::libtorrent_exception'
C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\include\vcruntime_exception.h(45): note: see declaration of 'std::exception'
C:\QBittorrent\install_msvc64\base\include\libtorrent/error_code.hpp(503): note: see declaration of 'libtorrent::libtorrent_exception'
tracker.cpp
trackerentry.cpp
Generating Code...
bandwidthscheduler.cpp
filterparserthread.cpp
resumedatasavingmanager.cpp
speedmonitor.cpp
statistics.cpp
Generating Code...
connection.cpp
httperror.cpp
requestparser.cpp
responsebuilder.cpp
responsegenerator.cpp
server.cpp
Generating Code...
dnsupdater.cpp
downloadhandler.cpp
downloadmanager.cpp
geoipmanager.cpp
portforwarder.cpp
proxyconfigurationmanager.cpp
reverseresolution.cpp
smtp.cpp
Generating Code...
geoipdatabase.cpp
profile_p.cpp
rss_parser.cpp
rss_article.cpp
rss_autodownloader.cpp
rss_autodownloadrule.cpp
rss_feed.cpp
rss_folder.cpp
rss_item.cpp
rss_session.cpp
Generating Code...
searchdownloadhandler.cpp
searchhandler.cpp
searchpluginmanager.cpp
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(172): warning C4267: 'argument': conversion from 'size_t' to 'int', possible loss of data
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(181): note: see reference to function template instantiation 'std::array<T,2> Utils::Version<T,2,2>::parseList<StringsList>(const StringsList &)' being compiled
with
T=unsigned short,
StringsList=QList<QByteArray>
with
T=unsigned short,
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(84): note: see reference to function template instantiation 'Utils::Version<unsigned short,2,2>::Version<QList<QByteArray>>(const StringsList &)' being compiled
with
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(83): note: see reference to function template instantiation 'Utils::Version<unsigned short,2,2>::Version<QList<QByteArray>>(const StringsList &)' being compiled
with
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(82): note: while compiling class template member function 'Utils::Version<unsigned short,2,2>::Version(const QByteArray &)'
C:\QBITTORRENT\qBittorrent\src\base/utils/version.h(151): note: see reference to function template instantiation 'Utils::Version<unsigned short,2,2>::Version(const QByteArray &)' being compiled
c:\qbittorrent\qbittorrent\src\base\search\searchpluginmanager.h(39): note: see reference to class template instantiation 'Utils::Version<unsigned short,2,2>' being compiled
Generating Code...
bytearray.cpp
fs.cpp
gzip.cpp
misc.cpp
net.cpp
random.cpp
string.cpp
Generating Code...
lineedit.cpp
powermanagement.cpp
downloadedpiecesbar.cpp
peerlistwidget.cpp
peersadditiondlg.cpp
pieceavailabilitybar.cpp
piecesbar.cpp
propertieswidget.cpp
proplistdelegate.cpp
proptabbar.cpp
speedplotview.cpp
speedwidget.cpp
trackerlist.cpp
trackersadditiondlg.cpp
Generating Code...
addnewtorrentdialog.cpp
advancedsettings.cpp
autoexpandabledialog.cpp
banlistoptions.cpp
categoryfiltermodel.cpp
categoryfilterproxymodel.cpp
categoryfilterwidget.cpp
cookiesdialog.cpp
cookiesmodel.cpp
downloadfromurldialog.cpp
executionlog.cpp
fspathedit.cpp
fspathedit_p.cpp
guiiconprovider.cpp
ipsubnetwhitelistoptionsdialog.cpp
loglistwidget.cpp
mainwindow.cpp
messageboxraised.cpp
optionsdlg.cpp
previewselectdialog.cpp
Generating Code...
Compiling...
scanfoldersdelegate.cpp
shutdownconfirmdlg.cpp
speedlimitdlg.cpp
statsdialog.cpp
statusbar.cpp
tagfiltermodel.cpp
tagfilterproxymodel.cpp
tagfilterwidget.cpp
torrentcategorydialog.cpp
torrentcontentfiltermodel.cpp
torrentcontentmodel.cpp
torrentcontentmodelfile.cpp
torrentcontentmodelfolder.cpp
torrentcontentmodelitem.cpp
torrentcontenttreeview.cpp
torrentcreatordlg.cpp
torrentmodel.cpp
trackerlogin.cpp
transferlistdelegate.cpp
transferlistfilterswidget.cpp
Generating Code...
Compiling...
transferlistsortmodel.cpp
transferlistwidget.cpp
updownratiodlg.cpp
utils.cpp
programupdater.cpp
Generating Code...
articlelistwidget.cpp
automatedrssdownloader.cpp
feedlistwidget.cpp
htmlbrowser.cpp
rsswidget.cpp
Generating Code...
pluginselectdlg.cpp
pluginsourcedlg.cpp
searchlistdelegate.cpp
searchsortmodel.cpp
searchtab.cpp
searchwidget.cpp
Generating Code...
apicontroller.cpp
apierror.cpp
appcontroller.cpp
authcontroller.cpp
logcontroller.cpp
rsscontroller.cpp
synccontroller.cpp
torrentscontroller.cpp
transfercontroller.cpp
Generating Code...
serialize_torrent.cpp
webapplication.cpp
webui.cpp
Generating Code...
qrc_about.cpp
qrc_webui_webui_qmlcache.cpp
qrc_icons.cpp
qrc_lang.cpp
qrc_searchengine.cpp
moc_qtsingleapplication.cpp
moc_qtlocalpeer.cpp
moc_application.cpp
moc_filelogger.cpp
moc_stacktrace_win_dlg.cpp
moc_asyncfilestorage.cpp
moc_bandwidthscheduler.cpp
moc_filterparserthread.cpp
moc_resumedatasavingmanager.cpp
moc_statistics.cpp
moc_session.cpp
moc_torrentcreatorthread.cpp
moc_tracker.cpp
moc_filesystemwatcher.cpp
moc_connection.cpp
Generating Code...
Compiling...
moc_server.cpp
moc_logger.cpp
moc_dnsupdater.cpp
moc_downloadhandler.cpp
moc_downloadmanager.cpp
moc_geoipmanager.cpp
moc_portforwarder.cpp
moc_proxyconfigurationmanager.cpp
moc_reverseresolution.cpp
moc_smtp.cpp
moc_preferences.cpp
moc_rss_parser.cpp
moc_rss_article.cpp
moc_rss_autodownloader.cpp
moc_rss_feed.cpp
moc_rss_folder.cpp
moc_rss_item.cpp
moc_rss_session.cpp
moc_scanfoldersmodel.cpp
moc_searchhandler.cpp
Generating Code...
Compiling...
moc_searchdownloadhandler.cpp
moc_searchpluginmanager.cpp
moc_settingsstorage.cpp
moc_torrentfileguard.cpp
moc_lineedit.cpp
moc_powermanagement.cpp
moc_downloadedpiecesbar.cpp
moc_peerlistdelegate.cpp
moc_peerlistsortmodel.cpp
moc_peerlistwidget.cpp
moc_peersadditiondlg.cpp
moc_pieceavailabilitybar.cpp
moc_piecesbar.cpp
moc_propertieswidget.cpp
moc_proplistdelegate.cpp
moc_proptabbar.cpp
moc_speedplotview.cpp
moc_speedwidget.cpp
moc_trackerlist.cpp
moc_trackersadditiondlg.cpp
Generating Code...
Compiling...
moc_about_imp.cpp
moc_addnewtorrentdialog.cpp
moc_advancedsettings.cpp
moc_autoexpandabledialog.cpp
moc_banlistoptions.cpp
moc_categoryfiltermodel.cpp
moc_categoryfilterwidget.cpp
moc_cookiesdialog.cpp
moc_cookiesmodel.cpp
moc_deletionconfirmationdlg.cpp
moc_downloadfromurldialog.cpp
moc_executionlog.cpp
moc_fspathedit.cpp
moc_fspathedit_p.cpp
moc_guiiconprovider.cpp
moc_ipsubnetwhitelistoptionsdialog.cpp
moc_loglistwidget.cpp
moc_mainwindow.cpp
moc_messageboxraised.cpp
moc_optionsdlg.cpp
Generating Code...
Compiling...
moc_previewlistdelegate.cpp
moc_previewselectdialog.cpp
moc_articlelistwidget.cpp
moc_automatedrssdownloader.cpp
moc_feedlistwidget.cpp
moc_htmlbrowser.cpp
moc_rsswidget.cpp
moc_scanfoldersdelegate.cpp
moc_pluginselectdlg.cpp
moc_pluginsourcedlg.cpp
moc_searchtab.cpp
moc_searchwidget.cpp
moc_shutdownconfirmdlg.cpp
moc_speedlimitdlg.cpp
moc_statsdialog.cpp
moc_statusbar.cpp
moc_tagfiltermodel.cpp
moc_tagfilterwidget.cpp
moc_torrentcategorydialog.cpp
moc_torrentcontentfiltermodel.cpp
Generating Code...
Compiling...
moc_torrentcontentmodel.cpp
moc_torrentcontenttreeview.cpp
moc_torrentcreatordlg.cpp
moc_torrentmodel.cpp
moc_trackerlogin.cpp
moc_transferlistdelegate.cpp
moc_transferlistfilterswidget.cpp
moc_transferlistsortmodel.cpp
moc_transferlistwidget.cpp
moc_updownratiodlg.cpp
moc_programupdater.cpp
moc_apicontroller.cpp
moc_appcontroller.cpp
moc_authcontroller.cpp
moc_logcontroller.cpp
moc_rsscontroller.cpp
moc_synccontroller.cpp
moc_torrentscontroller.cpp
moc_transfercontroller.cpp
moc_webapplication.cpp
Generating Code...
Compiling...
moc_webui.cpp
qmlcache_loader.cpp
Generating Code...
Compiling...
Generating Code...
linking release\qbittorrent.exe
06:57:30: The process "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\HostX64\x64\nmake.exe" exited normally.
06:57:30: Elapsed time: 07:13.
Screenshot :
How to proceed with case to fix the webui?
