After changing ISPs, I cannot download torrents.
crybllrd
Post by crybllrd »
I just moved to a new place and fired up qB to find I can't seem to connect to anyone.
The finished ones were previously downloaded, the one at the top is the one that won't start.
It has a couple thousand Se and Le, and I have also tried a few other torrents/magnets that had tens of thousands of Se and Le.
I haven't changed any settings since it last worked, but I did make sure I had firewall exceptions and I tried randomizing the ports in qB.
I have access to my router but all the settings look default.
What else can I try?
Switeck
Re: After changing ISPs, I cannot download torrents.
Post by Switeck »
Is the ISP giving you an unfirewalled non-LAN IPv4 address?
...Because the bottom of your screenshot suggests qBitTorrent is firewalled by by something. (yellow light at middle?)
