How to refresh a completed Search?
AnthonyB
Post by AnthonyB »
I started using the torrent Search feature of qB quite a bit of late (especially with the Jackett plugin which is awesome).
My question is: after a Search is complete, is there any way to "refresh" a Search?
It is great that qB keeps a tab for each Search but right now, the only way I can see to re-perform a Search using the same search criteria is to perform a new one which requires me to re-type the search criteria which then opens a new tab.
Assuming I haven't missed something obvious, a feature I'd love to see added is the ability to "Refresh" a Search tab using the same criteria. If this is not currently possible please let me know and I'll raise a feature req in Github.
Re: How to refresh a completed Search?
Yeah I've tried but I don't think this functionality exists.
But the ticket already exists: https://github.com/qbittorrent/qBittorrent/issues/15599
You can star the issue to show that you are interested as well.
higrm
Post by higrm »
Thanks for the reply and the link. :)
