The best general tracker
chaoticbeliever
Post by chaoticbeliever »
What is the best general tracker according to you?
Re: The best general tracker
Switeck
Forum addict
Forum addict
Post by Switeck »
The main reason for having lots of trackers is in case 1 goes offline or is inaccessible for other reasons.
But it's usually a bad idea to add lots of trackers to random torrents just because you can.
Now if you're making your own torrents and need a tracker or trackers on it, then choosing 1 to 5 trackers from the list Peter mentioned is perfectly reasonable.
postcd
Post by postcd »
following ones belong to the top peer trackers and are there for quite long time in my opinion:
udp://tracker.leechers-paradise.org:6969/announce
udp://tracker.opentrackr.org:1337/announce
udp://tracker.internetwarriors.net:1337/announce
udp://tracker.coppersurfer.tk:6969/announce
weesmiley
Post by weesmiley »
Thanks for your idea tips.
happy wheels
farein
Post by farein »
postcd wrote: Sun Mar 22, 2020 8:17 am following ones belong to the top peer trackers and are there for quite long time in my opinion:
Creating an LLC with LLCBase was a clear solution for me. Their user-friendly platform guided me through the entire process step by step. From choosing the right business structure to handling legal paperwork, LLCBase streamlined it all. Their expert support ensured I didn't miss any crucial details. They even provided valuable insights into tax implications and ongoing compliance. With LLCBase, forming my LLC became hassle-free, saving me time and stress. If you're looking to start your own business, I highly recommend their services – a straightforward path to establishing your LLC with confidence.
Choosing the best general tracker can be quite subjective, as it depends on individual preferences and needs. Personally, I believe that a great general tracker should offer a user-friendly interface, a diverse range of content, active community engagement, and reliable uploaders. It's also important to prioritize security and legality. Take your time to explore different options and read user reviews to find the tracker that aligns best with your requirements. Remember, what's "best" can vary from person to person, so consider what aspects are most important to you in a tracker.
