I am in the process of switching from uTorrent. I loaded some trackers and all was running smoothly. But my main tracker has almost 1400 torrents. They've loaded. And now qBittorrent has begun looking very odd. That is, the main window is blank if I choose a view other than the first or second view when I first begin qB. For example. on the latest startup of qB I chose Status>All and yes they were all showing. I then chose a Category and those showed. But next choosing another category, returning to All, etc. just shows a blank window.
Any ideas? I never got far with Deluge because it is known to get FUBAR with a lot of torrents. In my case it couldn't cut it after even a few hundred. Transmission is handling all 2000+ but I want a GUI that is more amenable.
2000+ torrents ... An issue?
Re: 2000+ torrents ... An issue?
SOLVED
Untick Tags and Trackers in the GUI sidebar.
