Hello everybody,
I'm using QB nox 2.9.3 through a web interface and sometimes when I'm trying to add a file in download it discard the file.
Unfortunatelly I was not able to find the log file in order to be more accurated.
Based on my experiece this "bug" appears more easily when the .torrent file is bigger than 15kbytes.
Have you already experienced this problem? Any idea?
I hope to post my issue in the right place and I'm available for further details
Regards
QB nox doesn't work with all the trackers
Re: QB nox doesn't work with all the trackers
Sorry guys for bothering, maybe my request is not clear enough. Can I support you with specific details?
So... the problem comes up when using given trackers AND torrent files bigger than 15kbytes?
Or just files that are bigger than 15kbytes?
