Does set location remove all the files from the previous one?
alex.louismorlevat
Post by alex.louismorlevat »
Hello
When I am on the list of downloading torrents.
I click on "Set Location" on a downloading OR downloaded torrent.
Will the location be moved.
>ill the files in the old location automatically deleted or should I delete it manually?
Or is it sent in a temp or special folder that I have to delete/empty from time to time so I don't have too much space used on my local SSD drive for nothing?
THANK YOU SO MUCH
ALEX
ItWasSooted
Re: Does set location remove all the files from the previous one?
Post by ItWasSooted »
There's no need to do anything as all the files are moved to the new location.
postcd
Post by postcd »
i agree, though if you manually created some files in the previous location, the folder with these files will remain i think.
Also i would be cautious about not to have any files open (example playing in media player) so the moving is not prevented.
