Adding new torrents to top of the download list
dm01
Post by dm01 »
Hello is there a setting for this ? I can't find it, thanks.
rrrevin
Re: Adding new torrents to top of the download list
Post by rrrevin »
There isn't.
Dogmeat
Post by Dogmeat »
Thought I'd check to see. It's now 4 years later they've still not added such an option eh? Too bad. Well it's a quality of life thing not a bug so understandable...
unseen19
Post by unseen19 »
You can change the D/L priority. Add the column "#" to your QBT interface to check the order (number will be displayed) then when multiple torrent are downloading you can select the one you want at the top of the list (or higher, bottom, etc).
This is an existing feature. Adding options to add new torrent on top of existing ones by default not so far I know.
but you can manage it yourself. Please add a feature request on the Git if you think this is a general benefit
