Using Tab key to select single file
ylem
Post by ylem »
I try to use the keyboard for navigation as much as possible, and have posted before about putting keyboard shortcuts in the context menus etc.
Does anyone know how to use the Tab key to navigate to and select a single file?  In a torrent with multiple files, I can tab from the torrent-list into the torrent-details window, hit Alt-Z to select the Content tab, then use the down arrow to move between and select/deselect files/folders using the space bar.
This method doesn't work for torrents with a single file—it can't be selected.  Even in a torrent with multiple files/folders, the spacebar doesn't work on the top file (like it's relying on an index that's using a minimum of 1 instead of 0?).  If anyone knows a way around this, please share.
Thank you!
