[official] qBittorrent v4.2.0alpha2_20190923_918 (64bit only)
Here is qBittorrent v4.2.0alpha2_20190923_918 build with MSVC 2017.
qBittorrent v4.2.0alpha2_20190923_918 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.1.13+git84f10d05ca
Qt: 5.13.1 (64-bit)
Boost: 1.71.0
TheBingoo
Re: [official] qBittorrent v4.2.0alpha2_20190923_918 (64bit only)
Post by TheBingoo »
I have had trouble installing the newest update to qbittorrent, but it says that the application is running even when its not, so i thought about deleting my current version to just install the new beta but that doesn't work either, is there a possible way to fix this problem? I also cannot install the current stable version either.
I'd definitely check Task Manager, in case the process is still stuck there.
Happens to me since 4.1.6 or so. The application icon is gone, and there is just a few megabytes process left, doing nothing.
If I close it "forcefully" nothing bad happens.
horeakaii2
Post by horeakaii2 »
Tampa screen repair Been finding this for a while! Thank you so much for your help through this.
