macOS tool for migration from Bittorrent/uTorrent/Deluge to qBittorrent
rumanzo
VIP
VIP
Post by rumanzo »
Original topic viewtopic.php?f=14&t=5889
Tested for Bittorrent/uTorrent clients (version 3+) and qBittorrent (4.2+) versions.
Features:
  • Processing all torrents
  • Processing torrents with subdirectories and without subdirectories
  • Processing torrents with renamed files
  • Processing torrents with non-standard encodings (for example, cp1251)
  • Processing of torrents in the not ready state *
  • Processing modified torrent names
  • Save date, metrics, status. **
  • Import of tags and labels
  • Multithreading
  • Path replace mechanism
* This torrents will not be done (0%) and will need force rehash
* If you migrate from windows to linux and use replace function attention that multiple flags -r processing one by one
* If you migrate from windows to linux and yours torrent files saves to some place you must use flag --search with actual paths in yours system
* If you migrate from windows to linux you may need to define path separathor with --sep flag
** The calculation of the completed parts is based only on the priority of the files in torrent. Don't transfer global uTorrent/BitTorrent statistics.
*** Partially downloaded torrents will be visible as 100% completed, but in fact you will need to do a rehash. Without rehash torrents not will be valid. This is due to the fact that conversion of .dat files in which parts of objects are stored is not implemented.
Don't forget before use make backup bittorrent\utorrent, qbittorrent folder. and config %APPDATA%/Roaming/qBittorrent/qBittorrent.ini. Close all this program before.
Usage:
If you MacOs user or Linux user don't forget to make the file executable:
$ chmod +x bt2qbt_v1.3_amd64_macos
1.) Help (from cmd or powerwhell)
Usage:
  C:\Users\user\Downloads\bt2qbt_v1.9_amd64.exe [OPTIONS]
Application Options:
  -s, --source=         Source directory that contains resume.dat and torrents
                        files (default:
                        C:\Users\user\AppData\Roaming\uTorrent\)
  -d, --destination=    Destination directory BT_backup (as default) (default:
                        C:\Users\user\AppData\Local\qBittorrent\BT_backup\)
  -c, --config=         qBittorrent config file (for write tags) (default:
                        C:\Users\user\AppData\Roaming\qBittorrent\qBittorren-
                        t.ini)
      --without-labels  Do not export/import labels
      --without-tags    Do not export/import tags
  -t, --search=         Additional search path for torrents files
                        Example: --search='/mnt/olddisk/savedtorrents'
                        --search='/mnt/olddisk/workstorrents'
  -r, --replace=        Replace paths.
                        Delimiter for from/to is comma - ,
                        Example: -r "D:\films,/home/user/films" -r
                        "D:\music,/home/user/music"
      --sep=            Default path separator that will use in all paths. You
                        may need use this flag if you migrating from windows to
                        linux in some cases (default: \)
Help Options:
  -h, --help            Show this help message
2.) If you just run application, it will processing torrents from %APPDATA%\uTorrent\ to %LOCALAPPDATA%\qBittorrent\BT_BACKUP\
Example:
It will be performed processing from directory C:\Users\user\AppData\Roaming\uTorrent\ to directory C:\Users\user\AppData\Local\qBittorrent\BT_backup\
Check that the qBittorrent is turned off and the directory C:\Users\user\AppData\Local\qBittorrent\BT_backup\ and config C:\Users\user\AppData\Roaming\qBittorrent\qBittorrent.ini is backed up.
Press Enter to start
Started
1/2 Sucessfully imported 1.torrent
2/2 Sucessfully imported 2.torrent
Press Enter to exit
3.) Run application from cmd or powershell with keys, if you want change source dir or destination dir, or export/import behavior
Example:
C:\Users\user\Downloads> .\bt2qbt_v1.3_amd64.exe -s C:\Users\user\AppData\Roaming\BitTorrent\
It will be performed processing from directory C:\Users\user\AppData\Roaming\BitTorrent\ to directory C:\Users\user\AppData\Local\qBittorrent\BT_backup\
Check that the qBittorrent is turned off and the directory C:\Users\user\AppData\Local\qBittorrent\BT_backup\ is backed up.
Started
1/3233 Sucessfully imported 1.torrent
2/3233 Sucessfully imported 2.torrent
3/3233 Sucessfully imported 3.torrent
3231/3233 Sucessfully imported 3231.torrent
3232/3233 Sucessfully imported 3232.torrent
3233/3233 Sucessfully imported 3233.torrent
Press Enter to exit
Known issuses:
  • Unknown
Here's the project: https://github.com/rumanzo/bt2qbt
Code:  https://github.com/rumanzo/bt2qbt/blob/master/bt2qbt.go
Releases: https://github.com/rumanzo/bt2qbt/releases
Deluge branch:
Here's the project: https://github.com/rumanzo/deluge2qbt
code: https://github.com/rumanzo/deluge2qbt/b ... uge2qbt.go
Releases: https://github.com/rumanzo/deluge2qbt/releases
If there are any errors or if it help you - write there
rumanzo
VIP
VIP
Re: macOS tool for migration from Bittorrent/uTorrent/Deluge to qBittorrent
Post by rumanzo »
rumanzo wrote: Sun Feb 16, 2020 2:45 pm Original topic viewtopic.php?f=14&t=5889
Disappointed in the existing application on the ruby, which could not handle all my torrents, I wrote my own application on golang.
I tested it on my own torrent database (3k+) and test torrents on Bittorrent/uTorrent clients (version 3+).
Features:
  • Multithreading
Usage:
 C:\Users\user\Downloads\bt2qbt_v1.3_amd64.exe [OPTIONS]
                        files (default:
  -c, --config=         Source directory that contains resume.dat and torrents
                        files (default:
                        t.ini)
Help Options:
Example:
Started
Press Enter to exit
Example:
Started
Press Enter to exit
Known issuses:
  • Unknown
Deluge branch:
sniffdoz
Post by sniffdoz »
Hi
Thank you for the tool :)
I have some issue on Mac OS version 11.5.1 Big Sur
I use this command : bt2qbt_v1.11_amd64_macos -s /Users/me/Library/Application\ Support/uTorrent\ Web
Where there is the file : resume.dat
I obtain this error message : Can't decode uTorrent\Bittorrent resume file
Utorrent version : μTorrent Web Version 1.2.7.4187 (9051)
qBittorent v4,3.9 (64bits)
Thank you for your help :)
Yannick
