[official]qBittorrent 4.2.5 installer - Built with MSVC 2017
Link to 4.2.5 post-> viewtopic.php?p=33743#p33743
*****ORIGINAL POST BELOW****
Here is qBittorrent 4.2.0 built with MSVC 2017.
4.2.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.2.2+git7b0bb2fb0b
Qt: 5.13.2
Boost: 1.71.0
Havokdan
Re: [official]qBittorrent 4.2.0 installer - Built with MSVC 2017
Post by Havokdan »
NOX11
Post by NOX11 »
Kaspersky reporting: Trojan.Win32.Badur.
Update your virus definitions. It is a false positive.
zetapulse
Post by zetapulse »
Congrats on 4.2! I just found the new Theme option in settings. Please tell me there's a dark theme I can download somethere!
sayg
Post by sayg »
I am using NordVPN VPN services with qbittorrent. After upgrading it to 4.2.0, I get 0 transfers via socks5/http NordVPN proxies. It works if I use qbittorrent without the proxies but I would like it to work with it. Does anyone have a similar problem? Is there any fix to it? I have tested the socks5 proxies with Firefox + proxy toggle extension and I have confirmed that it works.
CondoGhost
Post by CondoGhost »
sayg wrote: Thu Dec 12, 2019 3:30 pm I am using NordVPN VPN services with qbittorrent. After upgrading it to 4.2.0, I get 0 transfers via socks5/http NordVPN proxies. It works if I use qbittorrent without the proxies but I would like it to work with it. Does anyone have a similar problem? Is there any fix to it? I have tested the socks5 proxies with Firefox + proxy toggle extension and I have confirmed that it works.
I'm getting the same problem 0 transfers via socks5/http NordVPN proxies udp trackers Not Working though http trackers Working. 16-hours working on it.
I went through a sequence of checks Local Area Connection Network 3 Internet Protocol Version 4 (TCP/IPv4) DNS server addresses, Clear DNS Cache, Disable Local Area Connection Network 3, Enable Disable Local Area Connection Network 3, ipconfig /release, ipconfig /flushdns, ipconfig /renew, netsh winsock reset, netsh interface ipv4 reset, netsh interface ipv6 reset, netsh winsock reset catalog, netsh int ipv4 reset reset.log [There's no user specified settings to be reset], netsh int ipv6 reset reset.log [There's no user specified settings to be reset] - restart.
udp trackers still showing Not Working - they start working when No Proxy is set, they stop working when Proxy is set. However, after 15-mins with Proxy set Seeds and Peers appeared for two torrents loaded and downloading started and completed though Trackers Status is still showing Not Working.
Now, an hour later, I load a new torrent and still udp trackers Not Working and Seeds 0 Peers 0. Close client, clear app data temp files, restart PC, restart client with Socks5 proxy - udp trackers Not Working No Seeds No Peers torrent not downloading. Set proxy to none, close client, clear app data temp files, restart client, udp trackers Working, have Seeds and Peers and torrent is downloading. Reset client Proxy Server Socks5 Authentication, close client, clear app data temp files, restart client, udp trackers Not Working, however, have Seeds and Peers and torrent is downloading one seed though slower than without proxy. Force reannounce, 100% peers are discovered, one or two show downloading at very slow speeds disappearing and reappearing.
Guess I'll have to look at another client - uTorrent is no good as proxy settings simply don't work. Maybe give Deluge a go until this works out.
4.2.1 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.3+git68196dceae
Qt: 5.13.2
Boost: 1.71.0
(qt/boost weren't updated due to lack of time)
PIA, Windscribe and TorGuard SOCKS5 works just fine.
malakyas
Re: [official]qBittorrent 4.2.1 installer - Built with MSVC 2017
Post by malakyas »
hi, im newbie. i have a question when open qBT in temp folder create file name "qtsingleapp-qBitto-44a5-1-lockfile" plus folder .qBittorrent. The folder can be remove but the file qtsingleapp-qBitto-44a5-1-lockfile no. i have restart PC for i can do it.
Is this application behavior normal?
Sorry for my bad english.
Re: [official]qBittorrent 4.2.2 installer - Built with MSVC 2017
4.2.2 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.5+git0d06d47a29
Qt: 5.14.1
Boost: 1.72.0
damnit
Re: [official]qBittorrent 4.2.2 installer - Built with MSVC 2019
Post by damnit »
I was so looking forward, hoping really to see my work of Latgalian translation in this one. Sad. :/
JNavas
Post by JNavas »
sledgehammer_999 wrote: Tue Mar 24, 2020 5:59 pm 4.2.2 link-> http://www.fosshub.com/qBittorrent.html
Qt: 5.14.1
Boost: 1.72.0
Yikes! Huge increase in installer size (4.2.1 24.5 MB, 4.2.2 37.2 MB). What's up with that?!
But a bigger problem for me is that the UI scaling is HUGE on my high DPI panel (14" at 2560 x 1440),
and I can find no way to fix it. 4.2.1 was fine. 4.2.2 not so much. I've reverted to 4.2.1.
WIndows 8.1 Pro x64
Carambine
Post by Carambine »
Same problem with UI scaling here as well. I've got a 27" 4K panel and the font is comically large, barely useable. I've also reverted back to 4.2.1. I'd say the font is an equivalent of size 22 in word.
Rieha
Post by Rieha »
Hi.
I have a problem with version 4.2.2:
the downloaded files to the network storage (protocol SMB) are not distributed. Forced verification does not help.
