[official]qBittorrent 4.2.5 installer - Built with MSVC 2017
Re: [official]qBittorrent 4.2.2 installer - Built with MSVC 2019
Rieha wrote: Tue Mar 24, 2020 8:38 pm Hi.
I have a problem with version 4.2.2:
It worked before, correct?
Rieha
Post by Rieha »
Peter wrote: Tue Mar 24, 2020 8:46 pm It worked before, correct?
Yes, most of these files are downloaded versions 4.2 - 4.2.1 immediately to NAS to the directory \\192.168.1.1\AiDisk_a4\Фильмы\
downgrading did not fix the situation.
New files downloaded without problems.
judging by the log to the path of each network file added the installation path C:\Program Files\qBittorrent\
Log:
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Ведьмак". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Ведьмак\The.Witcher.S01E03.2019.NF.WEB-DL.1080p.HEVC.HDR.seleZen.mkv". Reason: The.Witcher.2019.S01.WEB-DL.1080p.HEVC.HDR.seleZen file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Ведьмак\The.Witcher.S01E03.2019.NF.WEB-DL.1080p.HEVC.HDR.seleZen.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Черное Зеркало". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Черное Зеркало\Black.Mirror.S05E01.Striking.Vipers.NF.WEBRip.1080p.mkv". Reason: Black.Mirror.S05.NF.WEBRip.1080p file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Черное Зеркало\Black.Mirror.S05E01.Striking.Vipers.NF.WEBRip.1080p.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Большая Маленькая Ложь". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Большая Маленькая Ложь\Big.Little.Lies.S02E01.1080p.TVShows.mkv". Reason: Big.Little.Lies.S02.1080p.TVShows file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Большая Маленькая Ложь\Big.Little.Lies.S02E01.1080p.TVShows.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Паразиты.mkv". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Паразиты.mkv". Reason: Паразиты (2019) BDRip 1080p [HEVC] 10 bit.mkv file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Паразиты.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Ford против Ferrari.mkv". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Ford против Ferrari.mkv". Reason: Ford.v.Ferrari.2019.2160p.UHD.BDRip.HDR.x265.10-bit.Master5.mkv file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Ford против Ferrari.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
(W) 2020-03-24T23:24:26 - File error alert. Torrent: "Заражение.mkv". File: "C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Заражение.mkv". Reason: Contagion (2011) BDRip (1920x1080) HEVC.mkv file_stat (C:/Program Files/qBittorrent///192.168.1.1/AiDisk_a4/Фильмы/Заражение.mkv) error: Синтаксическая ошибка в имени файла, имени папки или метке тома
JNavas
Post by JNavas »
Carambine wrote: Tue Mar 24, 2020 7:42 pm Same problem with UI scaling here as well. I've got a 27" 4K panel and the font is comically large, barely useable. I've also reverted back to 4.2.1. I'd say the font is an equivalent of size 22 in word.
See Issue #12248 qBittorrent GUI scaling is too large
John
Beban
Post by Beban »
Confirm the scaling issue. 4K @ 27" display, it's so big it's beyond usable.
NovaKing
Post by NovaKing »
I'm having the same issue after upgrading from 4.2.1
Example: Completed torrents are located at \\Server\Folder
When trying to resume them an error message says:
25/03/20 02:13 - File error alert. Torrent: "Movie.mkv";. File: ";C:/Program Files/qBittorrent///Server/Folder/Movie.mkv";. Reason: Movie.mkv file_open (C:/Program Files/qBittorrent///Server/Folder/Movie.mkv) error: The filename, directory name, or volume label syntax is incorrect
jb37
Post by jb37 »
Downloads and uploads all stalled after upgrading today. I've only used the client for less than a week, and I upgraded after the notification appeared. There were no errors in the log. I fiddled with my router and Windows firewalls as well as VPN. But even with all off, the Ubuntu torrent was recognized (seeds, peers), but the client refused to upload or download. I restarted my PC as well. I did NOT change any qB settings except to try several different random ports.
After finding this forum, I followed the suggestion to revert to the last version. I just installed it right over the top of the new one. All my torrents went right back to normal behavior. The port is whatever the last random was from earlier troubleshooting, so definitely different than the working port from pre-upgrade.
I can recreate again if that would be helpful. Good luck.
mzso
Post by mzso »
Is it just me, or the torrent list looks different with 4.4.2? Maybe the text is thinner? Is this normal?
I also have a huge issue of a new instance starting in portable mode when I open a torrent via double clicking a .torrent file and such.
abvmoose
Post by abvmoose »
JNavas wrote: Tue Mar 24, 2020 7:18 pm
sledgehammer_999 wrote: Tue Mar 24, 2020 5:59 pm 4.2.2 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.2.5+git0d06d47a29
Qt: 5.14.1
Boost: 1.72.0
Yikes! Huge increase in installer size (4.2.1 24.5 MB, 4.2.2 37.2 MB). What's up with that?!
But a bigger problem for me is that the UI scaling is HUGE on my high DPI panel (14" at 2560 x 1440),
and I can find no way to fix it. 4.2.1 was fine. 4.2.2 not so much. I've reverted to 4.2.1.
WIndows 8.1 Pro x64
Are you guys using DPI scaling in Windows?
@Carambine, What version of Windows are using, if 10, what build?
Carambine
Post by Carambine »
I'm using Windows 10 Pro 1909 Build: 18363.720 with 150% DPI scaling on a 4K 27" LG monitor connected via displayport to an Intel HD graphics 530 GPU running driver 26.20.100.7262.
All other apps including qbittorrent 4.2.1 are working as expected, only 4.2.2 quadruples the font size.
neiivaX
Post by neiivaX »
I am using DPI scaling and have the same issue.
Sorry, followed the git link and see that this appears to be resolved.
Feel free to disapprove my post.
Karel
Post by Karel »
Registered to let you know that setting dpiawareness=0 in qt.config fixes the DPI problem for the main program, but NOT for the RSS downloader screen in version 4.2.2. But this is no big deal.
A bigger problem is that the RSS downloading feature stopped working. For this reason I reverted back to version 4.2.1.
After reverting, the rss downloads are starting as before.
Re: [official]qBittorrent 4.2.3 installer - Built with MSVC 2017
4.2.3 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.5+gitdcf3c83d29
Qt: 5.13.2
Boost: 1.72.0
Thanks sledge.
Re: [official]qBittorrent 4.2.4 installer - Built with MSVC 2017
4.2.4 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.6+gita9968916ca
Qt: 5.13.2
Boost: 1.72.0
