Resuming 22 torrents takes about a minute after upgrade!
I upgraded from v4.1.8 (32-bit) to v.2.1.0 (32-bit) and now resuming 22 torrents I'm busy with takes about a minute instead of the 5-10 seconds it used to take. In this minute the title bar shows (not responding). Is this because you switched to a newer version of libtorrent and, if so, what's the point if it is so much slower? If I don't find a solution fast, I'm downgrading again.
