Stalling with other downloads to process
jaytaylormn
Post by jaytaylormn »
Quick question, I'm new to qBittorrent. Using 4.2.3 and earlier versions as well.
When I have more than one download pending and it stalls because of seeders/what ever, it just stops and doesn't skip on to the next download. Is there a setting I'm missing for this? I saw the note about not posting bugs in the forum but I don't know if this is a bug or setting issue.
Thanks for your help!
Jay
Robolov
Re: Stalling with other downloads to process
Post by Robolov »
This might indeed be a settings issue, do you have any custom parameters in torrent prioritization in Settings > Bittorrent tab?
jaytaylormn
Under Options / BitTorrent Here are my settings:
Enable DHT
Enable Peer Exchange (PeX)
Enable anonymous mode
Torrent Queueing
Max active down 1
Max active up 1
Max active torrents 15
I made a change to only have 1 active up/down. Is stalled still considered active? uTorrent would just go by it to the next torrent and then come back when all the others were downloaded. If that's not the case with qBittorrent, how do I get that behavior?
I don't want a stalled torrent to stop the other torrents from downloading/uploading.
Thanks,
Jay
