Hi
How do i uninstall qbittorrent completely om my mac?
I have already tried normal uninstall by dragging i into trash and then delete files in:
~Library/Application support
~Library/Caches
~Library/Preferences
~Library/LaunchAgents
I have also tried with Appcleaner app and the deleted reaming files like above, however something must remain
because when i install qbittorrent again it still knows my preferences from previous installation, what am i missing?
I want to do a fresh install of qbittorrent with no settings of my old installation.
Uninstall qbittorrent completely
Re: Uninstall qbittorrent completely
nobody knows the answer?
I have the same problem.
Thanks
Thanks
Have you tried deleting your user's preferences folder?
It's in:
Users / (username) / Library / Preferences / qBittorrent
It's in:
