hi, i’m runnin qbittorrent portable and searching i got the error
jackett apy key error…i click on its descriptions i see the web page and i see that my jackett.jason is configured as that page indicate…:
https://github.community/t/jackett-api-key-error/121293
so how to solve…?
thxs in adv
cheers
jackett apy
- Member
Re: jackett apy
Very basic questions to start off with...
Did you install Jackett?
Do you have it running in the background as a service?
Did you actually receive an API key?
Did you set up Jackett with at least one tracker?
Re: jackett apy
How do I get one?Did you actually receive an API key?
What does this mean?Did you set up Jackett with at least one tracker?
Sorry to be so dumb & thanks in advance for any help
- Member
