Notification sound
Notification sound
Newbie here, sorry for asking stupid question. How do you turn off notification sound after a torrent has completed download? Couldn't find in the options. Thank you!
Re: Notification sound
That's a Windows thing. You have to change the Windows sound / notification settings. OR you can simply disable the notification from Advanced Settings.
thx i was searching for settings => advanced settings => do not show notificationsPeter wrote: Wed Oct 14, 2020 2:46 pm That's a Windows thing. You have to change the Windows sound / notification settings. OR you can simply disable the notification from Advanced Settings.
