[official]qBittorrent 4.3.9 installer - Built with MSVC 2017
Re: [official]qBittorrent 4.3.2 installer - Built with MSVC 2017
The problem is not resolved, therefore I believe it is Malwarebytes making it; so I'll get onto them.
Re: [official]qBittorrent 4.3.3 installer - Built with MSVC 2017
4.3.3 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.2.12+git3efdb8a941
Qt: 5.15.2
Boost: 1.75.0
Qt: 5.15.2
Boost: 1.75.0
It hasn't been removed. It is renamed-reworked. Look at the screenshots here: https://github.com/qbittorrent/qBittorr ... -752929540
It sounds like someone made a really bad change & are refusing to accept it ? How about re-inventing everything else in qBittorrent so people end up not using it (cause it becomes so hard to do anything simple). I am sticking with version 4.3.1 as it is still working fine and meets my needs without having to change setting via menu options each time I download (do you even realize how awkward that is).
4.3.4 link-> http://www.fosshub.com/qBittorrent.html
WEBUI users don't install this release
Libtorrent: 1.2.13+git34a979720b
Qt: 5.15.2
Boost: 1.75.0
Qt: 5.15.2
Boost: 1.75.0
Re: [official]qBittorrent 4.3.4 installer - Built with MSVC 2017
Thanks sledge.
Important
WEBUI: It is accidentally broken in this release. A new release will be posted quickly. If you use the WebUI skip v4.3.4 for now.
Important
4.3.4.1 link-> http://www.fosshub.com/qBittorrent.html
WEBUI is now fixed
Qt: 5.15.2
Boost: 1.75.0
WEBUI is now fixed
Qt: 5.15.2
Boost: 1.75.0
- Newbie
Re: [official]qBittorrent 4.3.4.1 installer - Built with MSVC 2017
Yay. Five releases in a row now where the confirmed scaling/graphical bug that is even in the git "Frequent/important issues" section is still not fixed. Won't reverting back to Qt 5.15.1 fix this issue and Is there a reason Qt 5.15.2 HAS to be used?
Re: [official]qBittorrent 4.3.5 installer - Built with MSVC 2017
4.3.5 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.13+git22af326f6c
Qt: 5.15.2
Boost: 1.76.0
Qt: 5.15.2
Boost: 1.76.0
Could you impart any insight into qbt's release scheduling modus operandi?
Specifically, how many days in advance do we know of a target release day? Is it only a few hours, few days, or an entire week or two that a target is set in stone? And where are those declarations announced?
4.3.6 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.14+gitc996ed7ef7
Qt: 5.15.2
Boost: 1.76.0
Qt: 5.15.2
Boost: 1.76.0
Re: [official]qBittorrent 4.3.6 installer - Built with MSVC 2017
The beta can be found also on the same download page:In the meantime there will be a few beta releases of v4.4.0 until it hits stable status. If you use the betas then keep checking back for new betas because you won't get a program notification for them. Check once per week.
The v4.4.0beta1 uses the libtorrent 2.0.x series.
https://www.fosshub.com/qBittorrent.html
Thanks for the 4.4.0 betas on Windows, it keeps me from using Linux to get dev. builds
Has the disk cache setting been moved from Advanced menu or am I going blind?
4.3.7 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.14+git63d9634e51
Qt: 5.15.2
Boost: 1.76.0
Qt: 5.15.2
Boost: 1.76.0
