[official]qBittorrent 4.3.9 installer - Built with MSVC 2017
longwin
Re: [official]qBittorrent 4.3.7 installer - Built with MSVC 2017
Post by longwin »
Still don't have portable mode.
raccoon
Post by raccoon »
longwin wrote: Fri Aug 13, 2021 12:33 pm Still don't have portable mode.
Portable Mode is done by hand. In the "mIRC style" where you match exe and profile folder/config file of an existing install to wherever you want it. https://github.com/qbittorrent/qBittorr ... de#windows
longwin
Post by longwin »
raccoon wrote: Fri Aug 13, 2021 3:31 pm
Thanks. You are right. Wiki is wrong.
How do I extract qbittorrent.exe from qbittorrent_4.3.7_x64_setup.exe ?
The 7-zip says that he can't recognize the file format. Is there a 8-zip or 9-zip can recognize that file ?
Someone told me that you can first install qbittorrent and copy qbittorrent.exe & qbittorrent.pdb and uninstall qbittorrent.
He is right. But when new version is coming, I will install & uninstall again till no more new version.
I think that author is happy with us install & uninstall qbittorrent.
Anyone can fix this annoying problem ?
raccoon
Post by raccoon »
7zip does correctly extract qbittorrent.exe from the install package qbittorrent_4.3.7_x64_setup.exe by utilizing Windows Explorer right-click context menu -> select 7-Zip -> select either Open Archive or Extract Files menu options. The installer is 26.2 MB (27,516,526 bytes) with a CRC-32: 23fbfb1c, MD5: ed9e5fac69ee78dafd78d19851cbe3d8, SHA-1: 0ee38df19a537975cf5af66cfe2e28fb56b89c3c, SHA-256: d5ac29880966fd8e05daf6c9f95c303ba36caf505767c512d6e4d2f19d802f29
Edit the Wiki with corrected information if it is wrong.
longwin
Post by longwin »
raccoon wrote: Sat Aug 14, 2021 4:29 pm 7zip does correctly extract qbittorrent.exe from the install package qbittorrent_4.3.7_x64_setup.exe by utilizing Windows Explorer right-click context menu -> select 7-Zip -> select either Open Archive or Extract Files menu options. The installer is 26.2 MB (27,516,526 bytes) with a CRC-32: 23fbfb1c, MD5: ed9e5fac69ee78dafd78d19851cbe3d8, SHA-1: 0ee38df19a537975cf5af66cfe2e28fb56b89c3c, SHA-256: d5ac29880966fd8e05daf6c9f95c303ba36caf505767c512d6e4d2f19d802f29
I would like to say thank you so much much much !!!!
You solve my big problem.
Thank you again.
4.3.8 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.2.14+git1178e4e0f3
Qt: 5.15.2
Boost: 1.76.0
PS: To anyone wondering: Boost 1.77 wasn't used due to compilation problems.
Zoloft
Re: [official]qBittorrent 4.3.8 installer - Built with MSVC 2017
Post by Zoloft »
Thanks as always for keeping us cutting edge!
42n82rist
Post by 42n82rist »
I hope that I am the only (normally happy) user who is having problems with the ("qbittorrent_4.3.8_x64_setup.exe") installer in a Win10Pro desktop.
Even attempting to upgrade to V4.3.8 using 'admin privileges' results in nothing.
raccoon
Post by raccoon »
Make sure that your download wasn't incomplete / corrupt. File: qbittorrent_4.3.8_x64_setup.exe -- Size: 26.3 MB (27,597,604 bytes) -- CRC-32:c712bc34 -- MD5:6e7fa709cdf87c9bd2315c767ce10c00 -- SHA-1:bb5ff9e6d55a30ab31e90646db2d759708c6ade6 -- SHA-256:fd507bade63f51241d77d26ab48449281576287f44c560b9ec913981b0f99abf
42n82rist
Post by 42n82rist »
I have attempted to install V4.3.8 upon 3 different downloads of the same executable and checked hash but it still will not launch (or do anything) once launched. The TaskManager shows no running processes or services related to the qBT installer... Maybe V4.3.9 won't misbehave like this release version...
42n82rist wrote: Mon Sep 06, 2021 3:50 pm I have attempted to install V4.3.8 upon 3 different downloads of the same executable and checked hash but it still will not launch (or do anything) once launched. The TaskManager shows no running processes or services related to the qBT installer... Maybe V4.3.9 won't misbehave like this release version...
I mean, if it works for like thousands of people... it could be your PC..
42n82rist
Post by 42n82rist »
Peter wrote: Tue Sep 07, 2021 12:03 pmI mean, if it works for like thousands of people... it could be your PC..
I mean, maybe others were having similar issues. Maybe someday: you? ???
raccoon
Post by raccoon »
If you find it inconvenient to run the setup installer, then extract the fully functioning client from the setup installer, using 7-Zip as explained several posts earlier. PEBKAC is likely because an overly protective antivirus is interfering with your life, or your computer just hasn't been rebooted in a while, or who knows. The installer works for 10's of thousands of people so far. 7-Zip works for everyone else.
42n82rist
Post by 42n82rist »
raccoon wrote: Wed Sep 08, 2021 2:45 am...The installer works for 10's of thousands of people so far. 7-Zip works for everyone else.
My trusted PowerArchiver was utilized to unpack and successfully install the V438 update.
(Win10 built-in anti-Virus is the only aV running when package was refusing to upgrade.)
Thank you for the tip.
PowerArchiver
But why use a proprietary piece of software in 2021 when 7-zip is open-source and available for 100% free? ???
