insufficient system resources exist to complete the requested service
user637745
Post by user637745 »
I dont know if its related to the new version 4.3.1 but im getting "insufficient system resources exist to complete the requested service" seemingly randomly when trying to download stuff, anyone got an idea why?
Over 20GB ram free, CPU is fine, disk is fine etc
edit: when i disable cache, it doesnt happend, wtf :o
user637745
Re: insufficient system resources exist to complete the requested service
noone else got this?
What OS are you running? 64-bit? 32-bit?
user637745
Peter wrote: Mon Dec 21, 2020 7:25 pm What OS are you running? 64-bit? 32-bit?
64bit windows 10 pro, ive used qbit for many years, cant remember getting this
And are you sure, your disk is fine? This can happen when the RAM is filled because it cannot write out to disk for example.
- What kind of disk IO do you see while cache is enabled? What if you test disk with CrystaMark? (make sure to choose a bigger test size than your ram)
- https://docs.microsoft.com/en-us/sysinternals/ - use this tool to see what's in the ram when this occurs. (rammap.exe)
- Maybe check Event Viewer, see if you spot any critical errors as of lately.
