Invalid info_hash
johnEppp
Invalid info_hash
Post by johnEppp »
Suddenly all torrents from a specific tracker turned into "not working".
No seeding, not downloading new torrents. I can access their web interface.
If I access the URL http://site.net/announce.php?passkey=XXXXXXXXXXXXXXX through a browser I get the following error:
d14:failure reason24:Invalid info_hash (0 - )e
Any idea what could cause the issue?
Re: Invalid info_hash
Seems a problem with that particular private tracker.
You are a member of that site I assume or were you ghostleeching?
johnEppp
Post by johnEppp »
I am not ghost leeching (I dont even know what it is).
I am member of the site, I can login to the site, and download torrents. I have positive ratio (>1) also.
Suddenly all my torrents from this tracker stopped working.
New torrents also are not working.
I tried to change the hash on the tracker, still the same issue.
I disabled my PC firewall, just to ensure that its not accidentally blocked from it.
johnEppp
Post by johnEppp »
Using vuze I got a more detailed error description (instead of just an offline/refused).
It was an HTTP 403 error; finally was solved by the tracker.
Thank you
I knew it, thanks for your message.
