Move After Download
Shane
Move After Download
Post by Shane »
Greetings,
Is it possible to move a folder after it downloads?
When I go into Options > Downloads, what is the difference between "Copy .torrent files to:" and "Copy .torrent files for finished downloads to:"? They look like they both copy a file after it downloads.
Thanks,
Shane.
Re: Move After Download
It's possible.
1) You have to enable the "incomplete download folder"
Number (2) on the following pic:
Set a folder there, where you want your TEMPORARY files at.
2) You have to set your DEFAULT SAVE PATH to where you want your finished downloads.
YOU DON'T NEED TO MESS WITH 3 and 4.
squarecmb
Post by squarecmb »
I am making an assumption that by folder you are referring to the downloaded data. For that I use a number of categories. Each category has a different save location. When I change a torrent from one category to another it changes the torrent's location automatically. Your default "Torrent Management Mode" needs to be set to automatic for this to work. You can also move the location of the data by right clicking on the torrent in the interface and choosing set location.
Shane
Post by Shane »
Peter wrote: Tue Mar 30, 2021 12:51 pm It's possible.
This seems to be working.
Shane.
