Bad Image nvd3dumx_cfg.dll issue
YourMom
Post by YourMom »
When i start qb i get a qbittorrent.exe -bad image.
I have recent updated my graphics card, could that be to blame?
Ether way, reinstall doesn't fix. Any suggestions on how to fix? I have to click ok about 10 times and then it opens fine.
Re: Bad Image nvd3dumx_cfg.dll issue
Sometimes simply using Google to search something gives your answer:
https://www.freefixer.com/library/file/ ... ll-109941/
Yes, its GPU related, NVIDIA GPU. Try a fresh install after using DDU in safe mode and removing the current driver. Im using NVIDIA GPU too.
YourMom
Post by YourMom »
Sorry I only got the error when opening qb, so I figured it had more to do with qb than the card, I'll give ddu a try. Thanks
Alright, let me know if its fixed ;).
