these are the settings I can't figure out & instructions I've found so far that make no sense ...
Torrent Client Settings
Name - The name of the download client within Sonarr ... qBittorrent !?!?!
Enable - Enable this Download Client ... check !!!
I got this
Host - The URL of your download client .... locahost
Port - The port of your download client ... 8080
Use SSL - Use a secure connection with your download client. Please be aware of this common mistake.
URL Base - Add a prefix to the url; this is commonly needed for reverse proxies.
Url Base
Adds a prefix to the qBittorrent url, e.g. http://[host]:[port]/[urlBase]/api
the above 2 parts ain't adding up ..... & this is where I get stuck(like chuck) ...
Username - the username to authenticate to your client ... no log on credentials required
Password- the password to authenticate to your client ......OR password required on Qbitttorrent ?!?!?!?!?
Category - the category within your download client that Sonarr will use ... WHATEVER !?!?!
I ain't trying to use it for episodes ... just as the downloader client
Any Help will be appreciated !?!?!?!
