Not Connectable
jfbmm2002
Not Connectable
Post by jfbmm2002 »
Hi I have been using qbittorrent for quite some time . Lately (about 3 months) all the trackers show me as not connectable. I have tried all that needs to be done, followed instruction on many forums, used guidelines from FAQs and tried a lot yet I am not connectable. My downloads are ok and even my uploads but the trackers show me as not connectable. I am using qbittorrent 4.3.4.1. Please help
unseen19
Re: Not Connectable
Post by unseen19 »
(copy past from my answer to another topic)
-As UPNP is disabled (good) is your fixed IP still correct on the computer. Portforwarding correct too to this IP?
-Prior launching QBT is the defined port not used by another process ("netstat -ano")
-is the windows inbound firewall rules still present? If you select in it a program instead of just the port, the path is correct?
-anything in the logs?
-Configured port reachable from outside? (favorite search engine with query "check open port" will give you sites to do it
